Can a TPI system be put ona 4.3L v6?
Old Sep 12, 2010 | 02:39 PM
Da AZ Kid's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
I know chevy was working on 4.3 v6's for camaros for a while but never decided to produce these, usually they were tune port injected, this kind of sparked my curiosity. I know 4.3 v6s are similar to the chevy 350 and have heard some parts are interchangable. My question is would a TPI from a 305 or 350 actually work on a 4.3?
Old Sep 12, 2010 | 03:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can a TPI system be put ona 4.3L v6?
No
Old Sep 13, 2010 | 04:38 PM
S10Wildside's Avatar
You cannot attach 8 intake runners into 6 intake ports.
Old Sep 14, 2010 | 07:37 AM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
the best intake/fuel system for the 4.3 is the 98+ vortec system. it uses a spider fuel system and is very reliable. tpi is just out of the question unless someone redesigned it totally to fit a 6 banger.
Old Jan 6, 2011 | 06:01 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
And why should that be out of the question? I think it would be well worth it for those of us with 6 bangers as well as the S10 community who loves their 4.3L's. I can include myself in both of those groups...
A 60* V6 version, and a 90* V6 version, for someone who wanted to do it, theres money to be made...
PS: Sorry for reviving a dead thread
Old Jan 6, 2011 | 06:41 PM
A manufacturer will know that the market is too small for the costs involved.
Prototyping, testing, revisions, molds, fixtures, and so on. All of that for a lower base plate, runners, upper plenum, and fuel rail assembly.
Let's say you wanted to make a lower manifold. Someone has to design it, pay $30,000 or so for the sand cast mold, fixtures for CNC mill, and the milling itself.
Same for runners.
Same for upper plenum.
You still have costs involved with designing and manufacturing fuel rail extrusions and the CNC work involved there.
Dies have to be made for a gasket set.
Then The manufacturer needs to buy good quantities to get the best pricing. In other words, its extremely expensive to do a production run of 5 pieces.
Then you have emissions concerns (this limits the market).
Unless you have a mass market opportunity (like marine engine production), it is too costly to make a TPI system for V6 engines. And the marine manifolds are cast iron (enthusiasts don't want a heavy iron manifold).
Cost of production is too high.
Old Jan 6, 2011 | 10:14 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Yeah, if someone as an OEM parts manufacturer wants to do it and do it exactly step by step, and hit every single last detail. I'm talking about someone, one of us, that has the tools, and the time, and the knowledge to do it, along with help from this massive community. Its possible if some individual would be willing to do it, given there are a guaranteed number of those willing to purchase a final product. The initial cost of development, if done in house, could be paid for with a number of orders if secured. The biggest part would just be getting sensors to work correctly on an EFI system as complex as TPI.
All the proper dimensions could be ascertained from taking a TPI example and comparing it to the dimensions of a V6 intake/plenum. Make it all a ratio for each different intake, and then downsize it for 2 less cylinders, 2 less runners. Then, make the proper holes for vacuum lines, sensors, and so on. CNC machine could do all of that. If you can't do it with your own equipment, do it at a high school or local college. They would be more than happy to do it.
If all the numbers are the same for a V6 TPI intake as a normal V6 MPFI intake, then you wouldn't have to worry about adjusting sensors, or any of that. As far as the ECM would know, it would be operating just as normal, yet the performance would be improved.
Gaskets could be matched if designed correctly, and if its mounted in the same position as a normal V6 intake, then you would have no problems with the TV cable.
Of course the costs involved would be too large for a brand name company to do all the work to deliver us something that could potentially be home brewed. So why not?
GM already did all the work for us, its just a matter of adapting, and adapting is nothing thats hard to do....
Old Jan 6, 2011 | 11:20 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
http://www.michiganmotorz.com/images/DSCN4626-BIG.jpg
http://www.pacificp.com/forum/viewtopic.php?t=317
http://www.mercruiserparts.com/Show_...+and+Fuel+Rail
There's the marine version intake option,
The Edelbrock carbureted intake converted for MPFI option,
the custom sheetmetal intake option,
and there have been a couple of people that hacked two runners off of a GMPP ramjet350 intake and modified to seal up to the 4.3L. I have some pics of this, but not on this computer.
Having the individual external injectors makes it relatively easy to run the engine with a TPI ECM and code.
I'm sure someone could convert a TPI intake to fit, but it would be a LOT of trouble to complete.
Last edited by 305sbc; Jan 10, 2011 at 09:42 AM. Reason: fixing links that changed.
Old Jan 7, 2011 | 01:49 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
No.
Old Jan 7, 2011 | 02:36 PM
CamaroIROC88350's Avatar
Why would anyone want to do this anyway? Just get a 3800 series motor from a 98-2002 Camaro V6 if you want better V6 performance. If someone wants TPI then they should just get a V8. Costs and trials would be too much for someone to be willing to develop a TPI system for a V6.
Old Jan 7, 2011 | 02:45 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
No offense, but spoken from someone who doesn't understand having a Gen I 6/60
V6 guys will build hybrids, I say NO
V6 guys will turbocharge, I say NO
V6 guys will boost, I say NO
V6 guys will swap, I say NO, unless its a V8
Other than that, theres not much. Like I said before, GM did the work for us, we just need to adapt it. A hybrid is no better IMHO than a pieced up junkyard engine...boost is the for drag strip, and turbos are for people who wanted an easy way out.
Old Jan 7, 2011 | 02:53 PM
I'm not really sure how I would take offense to what you said but you don't know what I've had if that's what you were saying at first. I really like the 3800 series motor though, that was perhaps the best V6 GM made for the Camaro and Firebird, in my opinion.
Old Jan 7, 2011 | 02:56 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
I just still can't figure out why they didn't start it off right and put a 4.3L in it and call it a day....
Old Jan 7, 2011 | 03:12 PM
I don't know, lol, you got me on that one.
Old Jan 8, 2011 | 11:56 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
The only other stock mpfi from GM on a 4.3 was the Syclone typhoon engine , in fact it even uses an L98 throttle body. However to find that system for sale, is extremely rare. Especially the upper intake manifold.
Old Jan 8, 2011 | 02:00 PM
The throttle body casting is L98, but the linkage is all wrong for a TPI car.
The marine 4.3L vortec manifold has external injectors. I just purchased one brand new this past week for about $350 shipped. Includes manifold, cable throttle, fuel rails, and injectors.
Old Jan 10, 2011 | 09:35 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I uploaded the pics of the Ramjet intake mod here:
http://s702.photobucket.com/albums/w...20vortec%20V6/
Old Jan 10, 2011 | 11:50 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Thats badass
Old Jan 17, 2011 | 02:07 AM
Da AZ Kid's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
oh wow haha i havent been on here in a while i didnt think anyone was ever going to reply to this
you guys do have some interesting points though i appreciate you guys giving your opinions
Old Jan 17, 2011 | 02:10 AM
Da AZ Kid's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
oh wow haha
havent been on in a while i never expected anyone to ever reply to this
but you guys do bring up isome nteresting points though
Old Jan 21, 2011 | 09:56 AM
doctorcad's Avatar
Hmmmmm. 24x conversion with LS1 ecm?
I'm considering something along those lines myself. Any hiccups?
Old Jan 21, 2011 | 10:18 AM
You cannot run a 24x calibration with V6 engine.
Old Jan 21, 2011 | 10:33 AM
doctorcad's Avatar
58x with a 3 bolt DBW throttle body?
Old Jan 21, 2011 | 11:06 AM
Yes, that should work.
Fast355
Dec 2, 2016 06:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
