Anyone tried the L98 supercam from TPIS?
Old Sep 23, 2010 | 05:52 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Ok, I am wondering if anyone has tried out this cam and what the results were. I believe this cam is 220/220 @50 and 420/420 lifts. It is supposed to work with the stock computer. Let me know if you tried this cam and what you think. Later
Old Sep 27, 2010 | 12:54 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Anyone tried the L98 supercam from TPIS?
I have no personal experience with it but looking at the specs and considering the price, an LT1 or LT4 might yield similar performance for a LOT less money as they are plentiful in the used parts market.
Old Sep 27, 2010 | 09:00 AM
ninetyone's Avatar
Axle/Gears: 3:42
As far as I know an Lt1 cam is really no different than an L98 cam! and and Lt4 cam is only marginally better than an Lt1 cam. That is why I am asking because the supercam is advertised to give a 35-40 hp increase. I am aware that this is due to the amount of duration it comes with. Supercam duration @.50 = 220/220
Old Sep 28, 2010 | 12:08 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
The Super L98 cam has relatively mild lift characteristics and is most suited for an otherwise stock engine. Would work well with in an L98 but I don't know about 40 horses from just a cam that size with no head work. Also with that 112 lsa you might run into some vacuum issues more typical of much larger cams.
It all depends on how far you want to go. If that's all you want to do, would be a nice gain. But if you want to get more out of it, and maybe do some heads, you can't go wrong with some of the more aggressive cams out these days. The TPIS cam is old, like most cams that were designed for TPI, they are outdated by todays standards, but still good contenders. Check out the Lingenfelter 219/219 cam http://www.lingenfelter.com/mm5/merc...Category_Code= might be worth looking into.
Will
Old Sep 28, 2010 | 10:03 AM
watajob's Avatar
Car: 92 T/A 'vert
L98) 202/207, .413/.428, 114.5 (1.5)
LT1) 205/207, .447/.459, 117 (1.5)
LT4) 203/210, .476/.479, 115 (1.6)
TPI's like lift more than duration. And, the wider the LSA, the easier it is to tune.
Old Sep 28, 2010 | 11:10 AM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Interesting because when I asked TPIS there recommendation for my L98, they told me to put in a ZZ9 cam....
Old Sep 28, 2010 | 03:38 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Isn't the ZZ9 cam simular to the ZZ4 cam?
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
TheExaminer
Aug 19, 2015 10:07 PM
Sanjay
Aug 12, 2015 03:41 PM
