base timing question
Old Sep 23, 2010 | 10:38 PM
Msaby's Avatar
I have a 91 305 tpi (vin F) the timing I believe is to be 6degress is that 6 degrees BTDC?
Old Sep 24, 2010 | 12:42 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Re: base timing question
Yes, the base timing on that engine should be 6 degrees BTDC.
Old Nov 18, 2010 | 04:34 PM
diehard92's Avatar
Car: 90 Iroc-z tune port 350 mod
Engine: TPI 350 chipedout neck breaker tran
Transmission: 700R4 built
Axle/Gears: 7.5 10 bolt rear end
yes its 6 btc but you can run it a 8 or 9 and you will get the most out of you cam just a little secret lol
Old Nov 18, 2010 | 08:58 PM
ray jr's Avatar
dont you have to unplug something when you set the timing ?
Old Nov 18, 2010 | 09:04 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
You need to unplug the EST wire. That wire comes out of the wire loom on the passenger side of engine compartment. You can find out how to time your engine on the main page under FAQ, look under engines.
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
