Does any know what the OHMs should be on the Cold Start Valve (9th Injector) should be? Just trying to determine if my Cold Start Valve (9th Injector) is bad or the cold start temp sensor is, one of them is bad. Thank for the help. TonySenior Member
2.3Originally Posted by 1986iroc-z
Does any know what the OHMs should be on the Cold Start Valve (9th Injector) should be? Just trying to determine if my Cold Start Valve (9th Injector) is bad or the cold start temp sensor is, one of them is bad. Thank for the help. Tony Thank You.
if it is bad, if you haven't started looking im just gona tell you they don't make them anymore. i bought a block off kit off ebay for like $30
