355 Tpi (is this possible)
Old Oct 17, 2010 | 12:40 PM
dredre08's Avatar
Car: 1986 Trans Am/1988 Camaro Iroc-Z
Engine: 305 TPI/350 TPI
Ok I have a chance to get a rebuilt 355 sbc for a pretty decent price , the seller says it needs a carb and you know water pump,altenator etc..... well I have a 86 trans am with the stock 305 tpi and was just going to take the accessories off that but I'm not a fan of carbs and I want to keep my tpi setup so could I use the tpi off my 305 and put it on the 355 and if so what troubles would I run into??? here is the sellers description of the motor if this helps,its a 355 sbc with 305 high comp. heads. It has been hot tanked with newer pistons and new rings and bearings. Has a new lunati high rpm cam with new lifters and new roller tip rockers. Also has an edelbrock dual plane intake, dual roller timing chain and a new distributor..... any input would help guys I've been trying to get rid of this 305 for months........ here's a pic of the motor as well if it helps
Attached Thumbnails 355 Tpi (is this possible)-3na3pf3o05v05y25u3aa96588dfdc90261dc5.jpg
Old Oct 17, 2010 | 08:49 PM
91camarolover's Avatar
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
Re: 355 Tpi (is this possible)
I don't know if this is going to help any but my 85 Iroc was originally a 305 tpi and the last owner swapped in a 350 crate engine but he didn't say any thing about tuning or any thing
Old Oct 17, 2010 | 08:51 PM
88gta6spdvert's Avatar
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
you can keep tpi, just take heads up off your tpi and bolt on other motor.
Old Oct 17, 2010 | 08:53 PM
also have to buy a cam that is compatible with tpi computer call comp. cams.
Old Oct 17, 2010 | 09:59 PM
dredre08's Avatar
86dvert.... just askin Wats wrong with the heads that's on their now????
Old Oct 17, 2010 | 10:08 PM
90vertiroc's Avatar
Car: 1990 IROC vert
Transmission: 700-R4
Even if you were willing to go thru all that above, the ecm mem-cal would still need to be changed along with larger injectors just for the added fuel delivery required and on the 355.
Back to your original idea, your TPI will work with some mods, bigger injectors and a stock ecm from a 87-89 350 car will be a good starting point, but it will still need to be modified/tuned for the setup to work well on that 355.
Old Oct 17, 2010 | 10:17 PM
the angle in which bolt holes are , will not line up on the center ones on both sides.
Old Oct 17, 2010 | 10:38 PM
dredre08's Avatar
So just askin guys about how much do u think the cost will be for all necessary mods for tpi...or do u think It wud be better to just get a carbon and drop her in???
Old Oct 17, 2010 | 10:39 PM
dredre08's Avatar
So just askin guys about how much do u think the cost will be for all necessary mods for tpi...or do u think It wud be better to just get a carb and drop her in???
Old Oct 17, 2010 | 10:43 PM
dredre08's Avatar
Wat type of mods am I lookin at????
Old Oct 17, 2010 | 11:10 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
A lot of the answer has to do with how sweet of a deal the engine is. If it's good enough, you can get the cam, have some head work done and sell the new parts that came with the motor.
Old Oct 17, 2010 | 11:49 PM
dredre08's Avatar
Srs.... what type of head work am I looking at and do u have any good suggestions on an affordable cam
Old Oct 18, 2010 | 12:11 AM
90vertiroc's Avatar
Car: 1990 IROC vert
The injectors can be had for under $200 and I believe your ecm would actually be compatible with a 87-89 350 prom/mem-cal swiched into it, they can be had for less than $100.
The other mods I was refering to is to the prom itself, if you were to use a stock prom. The stock prom would have to be tuned/re-programed for the systems to control the engine properly. If you were going to order a new prom a reputable company can set the various sensor parameters to fit the specs of your new engine as it is, without switching the cam or heads.
Old Oct 18, 2010 | 07:07 AM
dredre08's Avatar
90vertiroc.... one last question,do u know of a reputable company I could get the prom from, and what do u estimate it will cost for the prom and for them to program it for the engine
Old Oct 18, 2010 | 07:25 AM
call Steven at Hawks he can probably help you find someone.864-855-2694.ext.11
Old Oct 20, 2010 | 01:03 AM
90vertiroc's Avatar
Car: 1990 IROC vert
Someone in DIY prom forum could give u the best advice on that one.
Reddeath210
Oct 6, 2015 08:20 AM
JHX
Aug 29, 2015 02:30 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
