dual fan motors 89 Iroc
Old May 22, 2026 | 02:25 PM
2irocs's Avatar
Car: 1989 Iroc Camaro
Engine: 383 Stroker-Carb Blue Print Engine
Transmission: automatic
Bought two cooling fan motors for my 89 Iroc the new motors seem like they pull more air...they are actually vibrating the bracket the fans are attached to... the fans are Continental PM 517 motors...know more air is good but concerned about the vibration...If you all have replaced stock cooling fan motors what brand...Thanks
Old May 22, 2026 | 03:34 PM
Re: dual fan motors 89 Iroc
I think I'd look into reinforcing the brackets instead of nutting the fans.
Post some photos of what you've got.
Old May 22, 2026 | 03:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
maybe make a aluminum y shaped stiffener for the plastic brackets
Old May 22, 2026 | 05:02 PM
2irocs's Avatar
It is all new from Hawks Motorsports top bottom mounting brackets, two fan mounting brackets, two fans and two motors plus hardware...it is a new reproduction dual fan kit...looks just like OEM...everything fits great looks great...fan motors pushing more cfm than stock a lot more...I will call Hawks after Memorial day...Thanks for any feedback...
Old May 23, 2026 | 11:10 AM
dannyual320's Avatar
That's what I would do. More airflow is a good thing but, obviously, they shouldn't be vibrating.
My first thought was that you have a fan blade out of balance but it looks like you replaced the fan motors and not the blades. Something must be up with the motor(s.)
Hopefully Hawks will make this right for you.
Old May 23, 2026 | 08:49 PM
2irocs's Avatar
Have the vibration fixed adjusted upper fan shroud...cut heater hose in 1 1/2 inch squares drilled bolt hole and installed on fan upper and lower mounting brackets to help vibration...it worked appreciate everyone's help...I did replace the blades also...
ChucksCamaro
Mar 30, 2012 10:01 PM
bbsr72
Jun 6, 2008 02:05 PM
souperman28
Jun 28, 2003 05:00 PM
T/A gets T&A
Jun 13, 2003 02:09 AM
T/A gets T&A
Apr 21, 2003 04:44 PM
