repeating problem in 86 and 89? MAF?
Old Oct 17, 2010 | 07:09 PM
Blitzkrieg91's Avatar
Car: 89 Iroc
MAF
that about sums it up. i can't figure it out. my 86 is the worse but isn't my major concern since the 89 is the daily driver...
89 350tpi- it will start right up but sometimes the RPMs will dip down for a second then go back to normal. as for once i start driving, 90% the time it drives fine. however my SES light comes on randomly and RPMs dip down again and it sputters if i hit the gas. sometimes it will die or pop. i was in a mcdonald's drivethru today and without warning it just died. restarted sputtered and died. did that one or two more times. then it started right and stayed fine. it feels as though the power is just being taken away and if i try and correct with the gas, then it goes lower and dies. my scanner says MAF too low.
86 305tpi- this is just aggravating, it started out similar to the 89 except didn't randomly stop running or die rarely. currently the car is on its last leg. if i figure the engine out i can fix her body. i have changed the fuel regulator, put a cold start block off kit on it thinking that may help, new MAF, replaced a knock sensor, one O2 sensor, new computer chip, new plugs, wires, and some other things i cant think of but may come back to me if mentioned. the car runs rich. and when i say rich i mean horribly rich. the plugs will fuel foul in a couple min. of run time and wont restart unless cleaned. when trying to start it turns and tries to fire, and if the plugs are clean then it may just start if you have your foot on the gas when it slightly fires. well if you get it started it runs bad, smoke out the back with a smell of fuel. low RPMs has a rough idle, mid range RPMs is a decent but not good idle, and high RPMs it will on sometimes pop and at full throttle will all but almost cut out and die. it also says that the MAF sensor is too low(i think it was too low, been a while since i worked on it) at one time i also had a code for the spark control module but that went away. i had my plentem apart to replace a sensor under it (forgot name of it) on the inter parts of my plentem it was coated in a black residue. so that to me was evident it was running too rich.
please, help me. i am on the breaking point with these damn MAF things...
thank you
Old Oct 17, 2010 | 07:19 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: repeating problem in 86 and 89? MAF?
The black in your 86 plenum is from the egr running exhaust gases back thru the engine. I would check all your vacuum lines for breaks or cracks. I struggled with my 87 for weeks, and found bad vacuum lines under the plenum and a leaky throttle body. Hope this helps.
Old Oct 17, 2010 | 09:54 PM
Car: 89 Iroc
ok i'll take a look
thanks
Old Oct 18, 2010 | 03:00 PM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
vacuum leaks or unmetered air (air entering the intake post MAF)... fo sho.
Break out several cans of starterfluid or brake cleaner and get to spraying areas of the engine, intake ducting and vacuum lines. If your engine rev's or stumbles when you spray, then you've found a leak.
edit: One more thing. Try disconnecting the MAF and see if it changes the way the car runs. That will tell you if the MAF is working.
Old Oct 18, 2010 | 05:11 PM
turbinator3's Avatar
dont forget to ohm the injectors. sounds like one or more are sticking! do a search on here about how to do it.
Old Oct 18, 2010 | 06:14 PM
red rock's Avatar
Car: 1987 iroc
Just curious if you have ever replaced the MAF relay's, not the sensor, but the burn off relay and the MAF relay. A code 33 or 34 can be tricky to find.
Old Oct 19, 2010 | 04:32 PM
Car: 89 Iroc
if i unplug the MAF it runs different. little better actually.
as for they MAF relay's...which ones are they? jw
Old Oct 19, 2010 | 05:05 PM
red rock's Avatar
Car: 1987 iroc
There are 3 relay's by your brake booster on the driver side firewall, 1 is fuel pump relay, (closest to the booster) then the MAF power relay, then the MAF burn off relay. They are black oblong with the wires on the bottom.
Old Oct 19, 2010 | 05:44 PM
Car: 89 Iroc
alright. i knew where and what they are, just not which one was which.
Old Oct 20, 2010 | 12:21 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
on the 89 the maf relays are oval shaped, on the 86 they are square but in the same place.
Old Oct 20, 2010 | 01:25 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Your 86 may have a faulty coolant temp sensor. An open or high resistance in the CTS circuit will cause the engine to run very rich. Generally you will get a code 14 for this but not always. You might check sensor resistance. Do you have a good repair manual? You should. I recommend you complete the diagnostic sequence for code 33.
chazman
Aug 28, 2018 03:25 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
GTAman
Sep 21, 2015 09:57 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
