Headlights flicker every 20 min
Old Aug 21, 2015 | 01:03 AM
1992CamaroGirl's Avatar
Car: 1992 Camaro RS
Engine: 8
1992 camaro here...anyone ever have problems with their headlights as to where they flicker and go off and on every 15-20 minuets , for about 5 minuets, than return to normal. Than repeat every 15-20 minuets. Also during the time the lights are flickering the high beams dont work either, and dome light works fine. Very frustrating!!! And can't really drive at night until gets fixed, so it's a huge bummer!!!
Old Aug 21, 2015 | 01:11 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Headlights flicker every 20 min
There should be a couple of headlight ground wires between the battery and radiator iirc.
Old Aug 22, 2015 | 06:17 PM
racerkilla's Avatar
Car: 85 iroc with 92 ground effects
Engine: 355 11.1 world product heads
Transmission: t56
Axle/Gears: 3.54 dana 44
I was having this problem with my h4 lights. I would flicker on high beam after 10 minutes of driving. I think it was overheating the light switch so I ended up running the high beam lights off its own 40 amp relay. Only thing the light switch has to power now is the relay. No more issues now.
Old Aug 22, 2015 | 08:11 PM
OrangeBird's Avatar
Car: 1989 Firebird
Exactly , when the lights cycle off and back on again repeatedly , it means too much current is being drawn in the headlight circuit and the circuit breaker built into the switch is doing it's job of keeping your wiring from melting it's insulation .
To 1992CamaroGirl ; If you have aftermarket headlights , like racerkilla does , the relay is the best way to stop the flickering . If you have stock headlights , you likely have a partial short to ground .
Old Aug 22, 2015 | 08:28 PM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Here you go, this should fix you right up for $40.00 Cant beat that. I have this harness and it works well. Solves alot of issues. Takes all of 15 minutes to install. see link below...
http://www.ebay.com/itm/Ceramic-H4-Headlight-4-Headlamp-Light-Bulb-Socket-Plug-Relay-Wiring-Harness-4X6-/330974040114?hash=item4d0f971032&vxp=mtr
ONE THING though.... Make sure you tell them the year of your Camaro. Mine didnt work when it arrived and they emailed me with how to repin the harness. If you message them before you buy they will repin the harness for you (its litterally swapping two wires around....easy)
Old Aug 26, 2015 | 10:20 AM
69-er's Avatar
Might also check the dimmer switch. Mine was flickering only on high beams. Switch R&R did the trick.
Old Dec 25, 2017 | 08:45 PM
MeestarGains's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I'm having the same issue, you think you could show a picture of where the wires might be?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
