View Poll Results: Can anyone help me on the wiring
L98 wiring
0%
ground
0%
Voters: 0. You may not vote on this poll
L98 swap
L98 swap
I got a l98 motor swap into 67 GTO and I can't get it to crank up it starts up on ether but cuts off immediately the pressure stays one second and then I might leave it alone for a couple minutes and then injectors will be open in the fuel pressure would be lost and I just can't get it injectors to fire up close when they're supposed to any help
Car: 1989 Pontiac Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 3:27
Re: L98 swap
First of all need more info.
1 Did you install the L98 engine with its original
harness, ecm and sensors?
2. What year and model was the L98 from?
Re: L98 swap
Engine: 5.7 TPI
Re: L98 swap
Is the gm ecm being used? Also probably be a good idea to have a gm 87 Corvette service manual that would provide wiring diagrams and diagnostic for the L98 electronics.
Engine: 5.7 TPI
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Re: L98 swap
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
