L98 Swap Finished
Old Nov 19, 2007 | 12:36 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
L98 Swap Finished
So, the L98 Swap is finally done and the car finally runs... So my question here is the L98 Block was brand new, what steps should I go through to properly break in the new motor? So far, I have driven it a very easy 50 miles... What should I do next?
Thanks in advance for any advise,
-Tim-
Old Nov 19, 2007 | 01:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There's a thread on the FAQ forum with the GM-recommended break-in procedure for crate engines. If your L98 is a true L98 with roller lifters, you can skip that part. If you have 50 miles on it already, you've already gone past the cam break-in part, anyway.
Old Nov 19, 2007 | 02:02 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
Re: L98 Swap Finished
Thanks a lot, I will go check that one out.
Old Nov 19, 2007 | 02:30 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Congrats on the swap!
Old Nov 19, 2007 | 02:48 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
Thanks, the L98 sure is a lot more drivable than the LO3. I love it
lt500r55
Sep 1, 2021 01:30 PM
InfinityShade
Aug 22, 2015 08:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
TheExaminer
Aug 19, 2015 10:07 PM
jharrison5
Aug 19, 2015 05:53 PM
