TPI Performance ?
Old Oct 29, 2010 | 08:58 AM
IROC343's Avatar
Car: 1987 Iroc Camaro
Engine: 383 GMPP TPI
Transmission: 5 Speed Manual
Axle/Gears: 10 Bolt 4:10 Eaton Posi Moser Axles
TPI Performance ?
I have an 87 IROC that I have installed a GMPP 383 engine with GM aluminum vortec heads. I have installed a comp cams cam, vortec TPI base, Edelbrock runners, Accell cdi ignition, Motovation custom prom, 58mm throttle body, Edelbrock shorty headers and Flowmaster 3" catback system. It has a 5 speed and 4.10 gears. It runs good, plenty of torque. I'm afraid to put any tire on it due to the flimsy 10 bolt rear. The engine feels as if it flattens out at rpms above 5000. Is this the nature of the TPI? Is there anything I can do to the plenum to improve this?
Old Oct 29, 2010 | 09:18 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Re: TPI Performance ?
If you use the stock TPI intake then yes. It will be able to support the engine until 4500-5000 RPM. Of course you can port the whole intake and that may help a little. Other choice is to use an aftermarket intake for your setup.
Old Oct 29, 2010 | 05:02 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Typical of all TPI intakes
Read this and compare the graphs
http://xtremecarzone.com.au/index.php?showtopic=386
Old Nov 8, 2010 | 02:33 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The Vortec TPI base is known for poor flow. Also, the Vortec heads, unless ported do not flow enough to support high RPM. Which Comp Cam do you have? To make power above 5,000, any engine needs to flow well. Also, cam duration plays a big role here. You can make power to and beyond 6,000rpm, even with long runner TPI, but its not cheap. High flowing heads, a high duration roller cam, ported high flow base and big runners are just the beginning.
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
theurge
Aug 21, 2015 12:46 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
Sanjay
Aug 12, 2015 03:41 PM
