355 build...need imput
Old Nov 3, 2010 | 10:51 AM
red/white04's Avatar
Car: 88 IROC
Engine: 305TPI
ok so my 350 short block is off to be freshend up. It will probably be .040 over. I'm currently going to put it in front of a 700r4 with a factory convertor. I'm not looking for crazy hp & tq just a mild street motor. I have a set of "brand new" 113 alum corvette heads that i'm using. I plan on having a light port and polish done to the heads and intake. I have a BBK 52mm TB. Talking to my engine builder the motor should be just a touch over 10:1.. what are my options on cam? The cam he sugguests is way too much for a computer to handel. So is what are my options?
Old Nov 3, 2010 | 11:25 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: 355 build...need imput
http://www.compcams.com Along with planning the build with your machine shop, make a phone call to the cam tech line for free advice.
Old Nov 3, 2010 | 03:07 PM
Car: 88 IROC
Engine: 305TPI
i wanna use either this cam
http://www.compcams.com/Company/CC/c...x?csid=78&sb=0
or this cam
http://www.compcams.com/Company/CC/c...x?csid=79&sb=0
i know the last one is cutting it close, would i have to up grade to how big of stall?
Old Nov 3, 2010 | 03:23 PM
Wadebryant's Avatar
I have a similar Comp 280 mag roller cam in my NA 6.0 motor. Needs the good stuff and a looser converter. You can choose either one but, you'll have to tune for it, new program too.
Old Nov 3, 2010 | 03:25 PM
Project-RS's Avatar
i have a 355 with the 212 comp cam. if your running anything over 10:1 your motor wont like anything under 93 octane or may need race fuel. im going with a bigger cam maybe next summer, but make sure the heads are clearanced for the cam you choose. my motor is around 400hp with alot of port work to my iron heads (pre 79 block and heads) do your homework before you start buying parts. esp when it comes to the valvetrain
Old Nov 3, 2010 | 03:27 PM
Project-RS's Avatar
heres my motor as it sits now.
Old Nov 3, 2010 | 05:39 PM
Car: 88 IROC
Engine: 305TPI
i can get away with more compression with the aluminum heads.. i always run premium gas anyway.. i had a 10.2 compression 355 cast iron headed motor before and never had any pre detonation issues.... i planned on taking it to a dyno to tune it properly
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
mike22115
Sep 28, 2015 04:49 AM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
