NEED HELP TPI RETROFIT
Old Nov 9, 2010 | 09:26 AM
faster1k's Avatar
Car: 89GTA, 62' GSXR1000-SS
Engine: 406-HSR
Transmission: Nocturnal
ok, i have a 70s 400 sbc block, with procomp 210 cc aluminum heads. a very budgeted build, and i cant afford the stealth ram right now..
My question is.. is there any way i can make the factory tpi work, because my intake ports are visible with the tpi base on.. or does anyone make a base intake to fit these heads? will post pics if your not following me
Old Nov 14, 2010 | 10:15 PM
NIDDLE's Avatar
Re: NEED HELP TPI RETROFIT
I don't know a whole lot about the TPI world, but I read a couple places where you weld some material to the edge of the intake to cover up the gap between the intake and head. I'd imagine it would work if you could make the added piece nice and flat where it mates to the head. I would also say you would probably have to do a little bit of grinding on the added piece to blend in to the original port of the intake. It all makes sense in my head and know it could work, I'm not all that good at explainig without pics. Don'tknow if it is worth the trouble or time, but like my dad always told me "what do you have more of, time or money?" Hope this helps some.
Old Nov 14, 2010 | 10:47 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Yes some weld and raise the injector bungs so they sit higher. Now not positive you may be able to leave the bungs alone but the injector will be a bit more in the path of airflow.
Old Nov 14, 2010 | 10:51 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Already been answered
https://www.thirdgen.org/forums/tpi/...even-have.html
You need a Vortec base to match the ports in the heads
Seeing as you have no money for the correct Vortec TPI base or a Vortec HSR; buy a cheap Vortec carb manifold and put a carb on it so it at least runs .
Most likely make more power than a stock TPI on a 406
Welding ports and machining would probably blow the same budget as a new intake anyway unless you can do it yourself
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
