L98 TPI to 13's - What mods?
Old Dec 3, 2010 | 07:36 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
What do you think is the easiest way to take a stock L98 and get it to the 13's?
Im assuming stock they run high 15's - low 16's. is that correct?
Old Dec 3, 2010 | 08:04 PM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
Re: L98 TPI to 13's - What mods?
Not sure if it would get you 13's but, Headers+Exhaust and a more aggressive cam that will still work with a TPI is a good start, And some good tires if you have trouble hooking.
And i believe you may be a little mistaken, The TPI L98 ran with the 5.0 mustangs when they came out, so that should near the high 14's? Not to sure, 14.3 is sticking in my head but so is 15.3, i cant remember. 14.8 to... but thats around there time. But im positive they didnt run 16's.
Old Dec 3, 2010 | 08:36 PM
insomniac's Avatar
Engine: 5.7 L98
yeah your probably right, i had a 5.0 TBI 1989 that i think i ran 16's with. so its gotta be better then that.
Old Dec 4, 2010 | 10:26 AM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
my 1992z ran 13.94 with k&n filters. air foil, under drive pulley
Old Dec 4, 2010 | 11:26 AM
Rod Behring's Avatar
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
A good running L98 should do mid 14s around 95MPH.
Bolt ons like headers and a good exhaust system and maybe 1.6 roller rockers would get you close. With good traction that should give you a high 13 around 99-100 MPH.
Old Dec 5, 2010 | 11:06 AM
ponykiller1187's Avatar
Car: 1987 camaro iroc z
Axle/Gears: stock
same my 87 iroc-z ran a 13.8 with only a exhaust, tranny shift kit with B&M shifter, cold air in take. got a 1.6 60ft with stock bf traction t/a tires which arent drag radials all i did was lower them to 20 pounds lol and hoped for the best. ran three runs the first was a 14 flat and the second and third were both 13.8s
Old Dec 5, 2010 | 01:12 PM
tross5592's Avatar
1.6 Rockers, Airfoil, Throttle Body Spacer, Shift Kit, and Hypertech Chip got me to 14.0's (coulda been 13's in the right air). Then I put on some shorty headers, 3.73 gear, and a 2800-3200 converter which put it into the 13.40's. Hope this helps ya.
Old Dec 5, 2010 | 08:17 PM
Rumblin70SS's Avatar
Car: 88 IROC-Z T-Top car with Bose
Engine: L98 5.7
Axle/Gears: 9 Bolt with 3.27's
My original 1988 IROC 350 went 13.96 in good weather (45 degrees) with a gutted converter, flowmaster muffler, modified MAF/airbox and underdrive pullies. Pretty much very low dollar stuff. It had 2.77 gears too and ran on street radials
My 1992 B4C went 13.92 in fair weather (70 degrees) with a modified airbox. This was also on street radials, but the B4C had dual converters and 3.23 gears which I think made the difference. It ran well......I'll bet it would have went 13.70's with more runs.....I only made 2 passes with it. Who said police cars weren't ringers??
The current 1988 IROC with 140k on it went 14.45 two weeks ago in good weather. All stock except a modified airbox and it was shifting at 4800 RPM. Thats pretty much where my original car started so minor mods and it will be there too.
Temperature (the car and weather) makes a huge difference. I have noted almost a 1/2 second in some cases.
Old Dec 6, 2010 | 09:58 AM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Bone stock with 51K miles, my formula ran 14.7 at around 93mph. With underdrive pulleys, SLP cold air, plugs wires and msd coil, edelbrock cat back now runs 13.8-14 flat depending on the temperature and air at the track. I played with the timing a while back and got it to do a 13.6 but that was advanced 8 degrees. Without adavncing the timing and with headers I feel it could do 13.6's or better consistantly.
Old Dec 6, 2010 | 08:15 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
my car did 13.94 @ 99mph
engine was a 355ci L98. stock TPI runners, plenum and manifold
stock unported L98 iron heads
93 LT1 cam, 1.5 full roller rockers (summit brand)
hooker 2055 headers and Y pipe, single 3" cat, 3" dynomax catback
6 speed trans with 3:42 gears
'92 speed density, Tuned by Kevin and Dyno Don
it was pretty much a stock engine, the 93 LT1 cam has a bit more lift and i was using a full roller rocker.... but other than that it was just a good exhaust system and an excellent tune
Old Dec 7, 2010 | 04:00 PM
badCHEVELLEman's Avatar
Car: chevelle + camaro
Engine: 520hp 350 350
Transmission: th 350 700r4
Axle/Gears: 4:56 3:23
Stock 350 ran 14.7 stock 305 ran 15.3 off the floor 3.73 gears should drop you in the high 13's. I have under drives pulleyshift kit DUI ignition and the bosh pink top injectors and flowmaster kit and ihave a best of 13.98 with stock 3.23 gears
Old Dec 7, 2010 | 04:54 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
My bone stock 90 5.7 G92 IROC went 13.7@100mph with a full exhaust system an a gutted air box with 190.000 miles on the motor. 3.23 gears. Remember a G92 car will be 3-4 tenths quicker than a non G92 car.
A stock G92 5.7 car will run 14.4@96
Old Dec 7, 2010 | 05:31 PM
What's makes it a g92
Old Dec 7, 2010 | 05:42 PM
VincentZ28's Avatar
Bigger sway bars, dual cats, flat top pistons, only built in hard tops, 1989 5.7 240hp, 1990-1992 5.7 245hp, PBR rear brakes.
The easiest way to identify a G92 car is to look under the car and see if it has dual factory cats an or 2 pipes just behind the front right tire.
Old Dec 11, 2010 | 07:00 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
G92 has to do with the performance rear end
Old Dec 11, 2010 | 12:42 PM
Car: 88 IROC
Engine: L98 HCI
This is correct.
The G92 option with an auto trans got you 3.23 (3.27 w/ 9 bolt) instead of 2.73/2.77 gears.
With a manual trans G92 got you 3.42 (3.45 w/ 9 bolt) instead of 3.08 gears.
The dual converter exhaust was option N10 and available 89-92. N10 came with G92 in those years.
Old Dec 11, 2010 | 04:48 PM
VincentZ28's Avatar
Yep they were the fastest thirdgens built in production.
Old Dec 11, 2010 | 04:49 PM
insomniac's Avatar
Engine: 5.7 L98
couldnt be faster then the 89 turbo trans am....
Old Dec 11, 2010 | 05:01 PM
VincentZ28's Avatar
Ok ok! The fastest L98 thirdgen built.
Old Dec 11, 2010 | 05:02 PM
insomniac's Avatar
Engine: 5.7 L98
was there a firebird/trans am equivalant?
Old Dec 11, 2010 | 05:23 PM
VincentZ28's Avatar
Yep!
Old Dec 11, 2010 | 05:36 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
best 1/4 was 13.21 in mid 50's. This artical was in 98* at Englishtown full boltons stock heads and cam.
http://www.gmhightechperformance.com...c_formula.html
Old Dec 14, 2010 | 07:17 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
headers, tb bypass, better catback with or without high flow cats, nice stall 2400 or higher, lower control arms, torque arm, panhardbar and some skinnys up front and slicks in back, rear girtle. shift kit. subframe connectors. ac delete setup. i think thats about all that was done to the car and it ran a 13.1 at 105. suspension and traction is key to any good times. do that before you go digging through the engine or throwing parts at it.
Old Dec 18, 2010 | 11:50 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
My 92 z28 l98 car g92 ran 14.6 at 95 mph with vortec heads, vortec intake, ported plenum and ported slp runners.. Had a horrible 60 feet and it was hot as hell
Old Dec 21, 2010 | 05:35 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
'88 GTA, 350 with 10.4:1, Y-LT1 cam, 1.6 roller rocker arms, ported stock base and SLP runners, airfoil, SLP shorties, high flow cat, Borla, custom CAI, Accel ignition, stock heads rebuilt with undercut stainless valves, 13.12. Gave my C5 a run for it's money up to about 90 MPH.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
matthew911
Aug 12, 2015 09:38 AM
