Advice, Very hard to start cold 1988 L98.
Old Dec 22, 2010 | 09:31 AM
jwilliams's Avatar
Guys,
When the car is cold it takes several attempts to start. Do you have any ideas as to what may cause this. I dont drive the car often but start it at least once a week. I generally drain the battery before it starts. Could this have something to do with the cold start injector?
Thanks for your help.
Old Dec 22, 2010 | 08:19 PM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
Re: Advice, Very hard to start cold 1988 L98.
could be a few things. Vaccum leak is what come to mind first, could be injectors, could be cold start injector.
Old Dec 22, 2010 | 11:16 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
check your fuel pressure, even change your fuel filter could be plugged
Old Dec 23, 2010 | 09:11 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
You could have a dead or plugged cold start injector. Try starting it with a spritz of carb cleaner in the intake next time and see if it starts easier.
jhawkeye
May 25, 2022 06:33 PM
jbd1969
Aug 17, 2015 07:06 PM
apie2546
Aug 10, 2015 05:43 PM
drathaar907
Aug 6, 2015 04:20 PM
