Anyone put AFR heads on stock cam/intake TPI 5.7?
Old Sep 24, 2011 | 02:21 PM
  #51
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Anyone put AFR heads on stock cam/intake TPI 5.7?
Originally Posted by Dyno Don
Have any of you tried it?
I have, changed just the heads and picked up 40 HP to the rear wheels, from 210 to 250.
I'm with ya. I did it back it the day on my 70k mile stock shortblock .
TFS heads 1.6 rr a stock ported intake, SLP runners plenum ported, SLP headers and cat back. I had the SLP stuff on waaay b4 the heads.. Cam came later !
Im not sure what it picked up but it was plenty for the day.
I also put AFRs TFS and several other heads on fox mustangs with well over 100,000 miles on them and run thier nuts off.. Still!!
I even put heads an TTkit on a stock shortblock stang with 150k on the clock! and its still runs low 10s n the 1/4..
Old Sep 24, 2011 | 02:53 PM
  #52
project89's Avatar
Originally Posted by ZZ3Astro
Yep that 60mm is definitely on the small side, not to mention a cheap ebay turbo. There are some 60's that will support more power and in my case I'm going to have to stay around 64-68mm because of clearance issues I think. I'm going to borrow my friend's Precision 67mm in a couple of weeks and see how that clears.
u could have a 70mm stuffed into ur current turbos housing. it does have a 4 inch inlet right?, though u would obviously want a turbine upgrade as well
i had an old ebay 61mm turbo and i think the housings are very close to the size of the mp t70 if not the same.
the precisions billet stuff is nice a billet 67mm wheel would outflow a standard 70mm anyways
when i built my setup i left enough room to upgrade to 70mm turbos for sure and might even be possible to fit a pair of 76mm's on there though i would need a seriously big ci wise engine to run that high. my 355 would prolly run its best with a pair of 61's/gt35's
if this setup dosent go fast enough for me i see a 434 ci build with a set of afr 227's and twin 70mm's in my future lol
Old Sep 24, 2011 | 05:08 PM
  #53
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Do what i am doing. twin 70's with 400 cubes and 245cc heads
CRFred
Feb 7, 2016 11:39 PM
camaro71633
Sep 1, 2015 10:24 AM
jharrison5
Aug 19, 2015 05:53 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
