Accel Injectors
Old Jan 24, 2011 | 07:19 PM
camaroman9191's Avatar
Accel Injectors
Hey all, I have a 1991 chevy Camaro Z28 with the 305 engine with the "F" code. Im rebuilding the engine and I'm looking at a set of Accel injectors that are 26 lbs./hr. Im wondering if Accel injectors will work with my car if they have a 14.4 ohm impedance and also if they are a good injector?? Thanks
http://www.summitracing.com/parts/ACC-150826/
Old Jan 24, 2011 | 08:25 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Accel Injectors
My experience with those is they are an off the shelf, unmatched injector. I am wondering why a 26 when stock is 19. Did you add 150 hp to support these?
Old Jan 24, 2011 | 08:31 PM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
Re: Accel Injectors
I wouldn't recommend those injectors, I've heard about them going bad quickly/not flowing right out of the box. Buy bosch inejctors from southbay or injectorsplus
Old Jan 24, 2011 | 10:34 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: Accel Injectors
pm'd
92-Formula
Dec 12, 2015 10:34 PM
85 Jimmy
Sep 30, 2015 07:56 AM
webeeZ28
Sep 14, 2015 12:00 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
