TPI Build Questions
Old Feb 3, 2011 | 11:18 PM
91fbGladback's Avatar
TPI Build Questions
Here are the specs for my motor swap into my 91 firebird:
Rebuilt 355 stock pistons
Comp Cams Extreme Energy 276hr
RPM Range: Valve Lash: Valve Timing: Duration: Lobe-Center Angle: Duration @ .050" Lift: Intake Centerline: Valve Lift: Lobe Lift: RPM Range: Valve Lash: Valve Timing: Duration: Lobe-Center Angle: Duration @ .050" Lift: Intake Centerline: Valve Lift: Lobe Lift:
World Products 200cc heads w/ matching comp cams valvetrain
Comp Cams Timing kit
350th transmission w/ 2200 stall
3.27 rearend <--changing to posi unit when i get the money
I have a stock tpi system from an 89 to put on this motor,
if i stick with the stock tpi what kind of hp am I looking at and
also what size injectors will I need?
I was also thinking of going with the holley stealth ram intake
setup. If i use this setup what size injectors will i be needing
and also what is the hp gain for the $1500 ill be dropping into this.
Old Feb 4, 2011 | 07:34 AM
InjectorsPlus's Avatar
Former Sponsor
Re: TPI Build Questions
Just pulling a number out of the air is irresponsible, but I'll do it anyway.
I'd probably look at 32-36lb off the top of my head to play it safe, but I'd like to see a desktop dyno of this combination to verify.
DD isn't a bible, but a guideline.
Old Feb 4, 2011 | 08:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Here are the specs
RPM Range:
Valve Lash:
Cut and paste is fine but did you actually look at what you put up???
There are no NUMBERS
For cam specs, all we need are duration @50,valve lift and LSA
so it should look like this
230/236 .540/.560 112
.. for the $1500 ill be dropping into this.
Why would you be spending $1500 on a HSR?
HSR can be had new for $600, some extra $$$ for lines and misc
Even cheaper used in the For Sale dept
https://www.thirdgen.org/forums/engi...thram-f-s.html
also what is the hp gain .
read
https://www.thirdgen.org/forums/alte...gal-whats.html
Old Feb 4, 2011 | 09:31 AM
Former Sponsor
Well, yeah VO, the fact that all that info is missing doesn't help either, I was trying to be polite, if you can believe that....
Old Feb 4, 2011 | 03:45 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Why start now JP; old age kicking in?
Shall we discuss heads?
Old Feb 4, 2011 | 04:10 PM
Former Sponsor
IF you get my twisted sense of humor, that's why I said we should do a DesktopDyno.
There's no information to put in...
I laughed, but don't know if anyone else got it.
And even the estimate of 32-36....joke. How would I know...
IDK sometimes I just amuse myself, but I hear that will make me go blind.
As to heads, nothing to discuss.....just go buy.......................................................
Old Feb 4, 2011 | 04:22 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I don't see the heads being ported. I don't see the HSR being ported either but I do know the cam. If I remember right that cam is either a 112LSA or 110LSA. The power will be around 340whp at the most. 30lbs will be good. The duty cycle will be around 65-70. That's where mine is and my engine is making 383whp@ 6000.
Old Feb 5, 2011 | 08:58 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
You might as well go ahead and change the intake to the holley now, seeing as your heads are so huge. If not you will have no "set" rpm power band with the stock tpi , i don't think. I think you should be fine with 24lb/hr injectors.
Old Feb 6, 2011 | 03:35 PM
tmoble's Avatar
Those heads are way too big for a near stock 350. You should be looking 180-195. squirts would be in the 22lb area.
Old Feb 6, 2011 | 03:55 PM
ninetyone's Avatar
Axle/Gears: 3:42
I would go even smaller on the heads , more like 165-170 cc heads. That is the range of the Vortec heads too.
Old Feb 6, 2011 | 03:59 PM
ninetyone's Avatar
Axle/Gears: 3:42
Also, your cam should be no lower than a 112 LSA. With the tpi, i would keep the duration under 220/220 @50.
Old Feb 6, 2011 | 04:01 PM
ninetyone's Avatar
Axle/Gears: 3:42
Honestly I would go get some used Vortec truck heads and slap a Scoggin Dickey tpi lower manifold on with a mild cam and enjoy 300 HP. Probably cost you $700 or less.
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
