Timing and injector questions
Old Feb 28, 2011 | 03:56 PM
banksGTA's Avatar
Car: 87 GTA
Axle/Gears: 3.42 posi
I jus rebuilt my 87 GTA which include 350 stock bore new pistons, crank, XR264HR-12 com cam with matching push rods and 1.6 roller rockers, slp ported runners and port matced upper and lower intake, egr and emissions delete, banks headers and full exhaust, and a superchip. Would it benfit me to up grade the injectors?if so what size? Also would i be able to tell a differance if i got a bigger throttle body? Also, im kinda stuck on what to aet the timing at? Any advice is greatly appreicated, thanks.
Old Mar 2, 2011 | 10:49 AM
Guest
Guest
Posts: n/a
Re: Timing and injector questions
Start with the stock timing of 6, it may or may not like 8 better. The stock injectors should be fine since you apparently still have stock heads. The only upgrade I'd suggest is the Bosch III style in 24# if you want to do a custom chip and ditch that superchip in there (probably a good idea). A different TB will be of no use on that combo.
Old Mar 2, 2011 | 11:22 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
MustangBeater20
Oct 29, 2022 09:20 PM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
