1989 TPI gasket change
I have an intake runner sucking air on my 89 305 TPI Camaro causing a lean misfire. I do some shade tree mechanic stuff, but I've never worked on a TPI system. Any tips on changing the intake runner tube gaskets? I just want to do it right the first time. Thanks.
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Re: 1989 TPI gasket change
Nope. Pretty straight forward. Just put it back the way you found it. Torque all the runner bolts to 25lb/ft. Start with the center bolts and work toward to ends on the plenum blots.
Good luck and get to it!
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
