Need TPI Diagnostic Advice - Not Starting
Old Mar 11, 2011 | 03:00 PM
BQuicksilver's Avatar
First post here, so I'm hoping this thread fits here (TPI) best since this is an engine issue in a finished swap.
Well, my brother purchased a 1970's 240z with a 305 TPI swap. The car has a 1990-92 style ECU and no MAF. Under his distributor he has an Accel 35362 Performance control Module.
The car always ran rich and now no longer starts. Obviously its likely fuel/spark. It's not a battery/starter issue. No recent work or new parts to blame.
Ran the little inline spark tester, and the coil is putting out spark. All 8 wires out of the distributor are getting spark. Plugs are new.
You can hear the fuel pump with the key in the on position. I thought I smelled fuel while turning it over with a plug out, but not 100% sure.
Any ideas? I asked at LS1Tech and they pointed me here but suggested checking fuel pressure (details how?) and the injectors (i do have a tester).
Thanks in advance!
Old Mar 11, 2011 | 08:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need TPI Diagnostic Advice - Not Starting
Put a fuel gauge on the test point of fuel rails and see what pressure you have
Use a noid light on a injector plug to see if you have the pulses required to fire the injectors
Check resistance of injectors; one bad or low resistance injector will shut whole injector bank down
Old Mar 13, 2011 | 02:32 PM
We did swap out the accel ignition control module today with no success.
specialized
Jun 18, 2022 09:26 AM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
