Injectors stuck open... HELP!!!
Old Mar 15, 2011 | 09:43 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Just rebuilt my engine and put around 75 miles on it. Well, I parked and when I went to restart it, it almost instantly flooded... so I pulled the spark plugs and let it sit for a while. Well I went to start it, and it just soaked the spark plugs instantly, and will not start. What would cause this?'
I have 24lb accel blue top injectors, and a BBK FPR on top of a mess of other things. 24lb injectors are about 8 years old with about 12k miles.
Could it be the Regulator Diapram? I sure hope so, as the superram is a PITA to pull and the gaskets are around 50 bucks...
Maybe the Injectors stuck open? Which I cant see happening as fuel is dumping in all the cylinders.
Old Mar 15, 2011 | 11:13 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Dumping Fuel... Wont Start? HELP!!!
I am lost. I literally drove it an hour before I didn't start.
Old Mar 16, 2011 | 03:00 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Does it get spark? An engine needs 3 things to run:fuel, air and spark. You have established that there is fuel, and air is a given, lol, so now check for the missing element...
Old Mar 16, 2011 | 03:23 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
It has spark without a doubt.
Old Mar 16, 2011 | 08:42 AM
JustCruzin's Avatar
Was never crazy about Accel injectors, that beeing said if the fpr was leaking I think you would see it back up in the vac line. Does the rail hold pressure? Hope someone else chimes in for you.
Old Mar 16, 2011 | 02:12 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
The rail holds pressure for a while, maybe a very slow leak, but I would assume that is normal.
Old Mar 16, 2011 | 02:37 PM
JustCruzin's Avatar
True, are all the injectors wet or just a few?
Old Mar 16, 2011 | 03:47 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Its the spark plugs... all soaked.
Old Mar 16, 2011 | 06:05 PM
southbay08's Avatar
Regulator diaphragms do dry out, you might want to check it. Check all of your sensors, if one of them is bad your computer will be receiving incorrect info.
www.southbayfuelinjectors.com
516-492-6504
Old Mar 16, 2011 | 06:11 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Long story, but stick with me..
Picked up a 88 IROC 'vert in a trade..
Went through 10 years of GM Dealership receipts trying to figure out the problem, mostly after the car had already been warmed up, it would flood itself and refuse to start for over an hour..
Did a bunch of research, changed around $300 in parts, mostly to help it run better..
Turns out the coolant temp sensor in the intake for the ECM was reading -180*C..
GM Dealer changed just about every part imaginable, even the fuel pump.
Try changing your temp sensor.
Old Mar 16, 2011 | 06:53 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Car is not pulling any codes... won't start. Floods instantly. I don't see it being the temp sensor. I will fiddle around more and will change it if it comes down to it. I don't see it being the diaphram either as it holds the fuel pressure in the rail.
Old Mar 16, 2011 | 08:01 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay, changed computers, and the chip. No change.
Unplugged an injector wire, no fuel came out, some injectors should be fine. Hooked up a multimeter to the injector wires... read fine.
Old Mar 17, 2011 | 01:36 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I did notice that the fuel pressure is a bit on the low side. Prob from not being able to build pressure because of the injectors being stuck open.
Old Mar 17, 2011 | 08:11 AM
JustCruzin's Avatar
Hate to see you toss money at it but may be a good idea to have them checked and cleaned, or maybe just have them replaced. Just a thought
Old Mar 17, 2011 | 11:33 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That is going to be a last resort... I know that isn't the prob though.
Old Mar 17, 2011 | 12:15 PM
southbay08's Avatar
So listen, why don't you send your injectors to us. We will put them on the bench and check them out....No charge. It will be one more thing that you can eliminate.
Old Mar 17, 2011 | 12:17 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Injectors stuck open... HELP!!!
i would try something simple like....
connect fuel pressure gauge, see what psi is there, then turn key on and see what happens, if it drops it's a bad injector(s)
i had one get stuck wide open and hydrolock the motor...
been running FMS 42lb injectors without issue
Old Mar 17, 2011 | 02:12 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I can't send them out. I would, but I leave back for japan on the 28th. They are all stuck open, so I don't believe. The injectors are the issue.
Old Mar 17, 2011 | 05:54 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
It's highly unlikely that all 8 injectors would suffer the same failure simultaniously. I would disconnect all eight and check injector pulse, better yet use a lab scope and look at injector waveform to be sure it's okay.
Be aware, once spark plugs become fuel fouled, they will not fire, even if the flooding is resolved. You may have a defective coolant temp sensor that caused it to flood initially, now the fouled plugs will never start the motor. You'll need to replace them. First check ECM with a scan tool, key on engine off, look for CTS to be way off. Someone said -180C, I don't know about that, the ECM will default to -34F if the CTS is open. That will cause the engine to severely overfuel, enough to flood the engine. Try clear flood, that's holding your foot to the floor while cranking. This shuts the injectors down to clear any excess fuel from the motor.
Old Jan 31, 2012 | 08:18 PM
tomckinney's Avatar
floods when i pull in fule pump
I TESTED MY INJECTIORS WHIT A TEST AND SHORTED SOMETHING OUT ON MY 1987 CROVETTE.WHAT COULD I HAVE BRUN OUT CAR WAS RUNNING FING BEFORE I SHORTED OUT THAT.I THINK I MAY HAVE BRUNED OUT THE POWER CONTROL MODULE.NEED HELP.I CHANGE OUT FULE PUMP AND FULE PUMP REALY FULE PRESSURE REGULATOR
Bubbajones_ya
Jul 6, 2024 08:32 PM
92-Formula
Dec 12, 2015 10:34 PM
ctoledo0834
Sep 18, 2015 04:16 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
