I give up. I need help
I have been lookign for an hour and a half now and I give up. I am trying to wrap up the wiring harness on my 88 TPI swap into my 73 GMC pickup. I am stuck at the VSS and VSS buffer. I'f I'm interpreting my diagram properly pin A10 is an in put from the VSS buffer. I have a unit from Jagsthatrun to make the VSS signal but no buffer. Is this input necessary for the vehicle running and do I have to have a VSS buffer to make this swap? Or is there another way? I have all 88 IROC stuff TPI, Engine, computer etc. Please help!!!
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: I give up. I need help
need a buffer. if you find one at a yard its easy enough to wire up.
MikkoV
Sep 9, 2015 04:25 PM
90formulaVortec
Sep 8, 2015 12:42 AM
