power steering switch
Old May 13, 2011 | 04:45 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
i did a swap from a '86 305 tpi to a '89 350 tpi i bought a '89 formula wiring harness complete for the same year setup but dont know if the harness was equipped for the power steering switch could i just change the lines to the regular ones with out the switch or do i need to keep the switch....i might have other questions related to this swap but ill go 1 question at a time please help
Old May 13, 2011 | 10:41 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: power steering switch
i read on here you can hook it inline with the a/c wiring to get a bump in idle during low speed turning? atleast im pretty sure i did. lol
Old May 13, 2011 | 02:32 PM
DiabloWS6's Avatar
thanks for the tip
Old May 14, 2011 | 08:57 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
My 87 had an LG4 (4BBL), I converted it to TPI, Originally it had the switch for the Power Steering... I left it there, nothing hooked up to it, it drives fine, never felt the need for it honestly...
John
Old May 15, 2011 | 03:01 AM
DiabloWS6's Avatar
some other people have stated that under slow turns or hard turns it might stall because its not inputing signal to the ecm
Old May 15, 2011 | 11:04 AM
Car: 91 formula ws6
Transmission: 4l60E
mine stalled the other day but my idle speed isnt high enough. i just swapped so im still working out the bugs.
Old May 15, 2011 | 04:13 PM
DiabloWS6's Avatar
i checked the '89 harness that i got and cant find the wire for it i know the color is green/red and black/white and i followed it to the main harness where all the wires meet the thickest part of the harness and doesnt have that wire
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
overdriv
Aug 20, 2015 03:52 PM
