Racetronix fuel pump/wiring harness??
Old May 18, 2011 | 04:19 AM
unprdictable1's Avatar
Anyone have the installation instructions for the "Racetronix" upgrade fuel pump wiring harness?? I just ordered the kit should be here Thursday, but I couldn't find a wiring diagram on there web site. I know how to install a new fuel pump, it's the upgraded harness from the engine compartment to the pump that I'm concerned with. Thanks
Tom
Old May 18, 2011 | 09:24 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Racetronix fuel pump/wiring harness??
you shouldnt need instructions 4 it at all. its very easy. you have a big red wire that runs right off your alt all the way back to where your pump wiring is. you'll unplug your fuel pump harness, plug the racetronics harness inline, hook up a ground wire to the frame then secure the big long red wire with zip ties along the frame/brake/fuel line area and your done.
Old May 18, 2011 | 12:45 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Ditto!
You can run the pump like factory if you aren't pushing the limits of that pump. I ran mine off the factory harness for a week before I found my racetronix harness and installed it and didn't notice a difference. I wasn't pushing the limits of my pump though. However, the whole point of using the racetronix pump is to kick up the voltage available to the pump so the pump works to it's full capacity.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86Base
Aug 13, 2015 05:06 PM
