Another Code 33 Question
Old Jun 14, 2011 | 12:14 PM
anomolee's Avatar
Ok, once again, 87 Iroc 305 TPI. I'm getting a code 33 so I know it's the maf circuit. If I start the car and run it then unplug the maf I get no change.
What is this telling me?
Old Jun 15, 2011 | 03:31 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: Another Code 33 Question
the either the MAF is bad or the wiring is bad, or your relay is bad, or all three
Old Jun 15, 2011 | 03:37 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Check the MAF relay, and the MAF burn off relay, along with all vacuum lines and the throttle body shaft for leaks.
chazman
Aug 28, 2018 03:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
