What should fuel pressure be set at?
Old Jul 16, 2011 | 12:46 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Tomorrow my fuel pressure gauge get's here and I can finally start my engine after many repairs. I installed a Holley AFPR because the diaphragm in the stock regulator was blown.
I was just wondering what I should set the fuel pressure to. What is the stock setting with engine off key on and at idle?
I have an 85 LB9 with headerback exhaust, ignition, free mods and a couple other things. I'm thinking 45lbs should be a good starting point.
Old Jul 16, 2011 | 08:44 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: What should fuel pressure be set at?
You should be alright at 45. I think stock FP was somewhere around 38-40psi. Just remember to set it with the vacuum line disconnected from the AFPR.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
