HELP fuel injectors
Old Sep 1, 2011 | 08:47 PM
my89camaro's Avatar
Car: 1989 Iroc-z camaro
Engine: 305ci HO
Transmission: manual 5speed
Axle/Gears: Borg Warner w/ 3.08 gears
HELP fuel injectors
what is the stock lbs rating for a 1989 305 f code fuel injector.
Old Sep 1, 2011 | 09:19 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Re: HELP fuel injectors
19lbs
Old Sep 1, 2011 | 09:26 PM
my89camaro's Avatar
Engine: 305ci HO
THANKS BRO, I think mine are shot and need replaced.
Old Sep 1, 2011 | 09:31 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Bosch III 19lbs from Southbay fuel injectors. Highly Recommended you order them from him. Stand up guy.
Old Sep 2, 2011 | 12:43 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
def a great company. love my set
Old Sep 6, 2011 | 10:19 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
19 lb BOSCH Series 3 are the way to go! I have yellow 19lb 4.6 FORD series 3 in my 305. Better spray pattern and atomization than the OEM parts. Cheap to buy as well. If your engine is close to stock, then this is all the injector you need. They will support all the power that most 305's will make. Southbay seems to have a good reputation. I bought mine on E-bay used, cleaned and matched for less than $100. It is nice to be able to use things that most people do not want, cheaper that way!
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
