88 Firebird Formula 350 won't fire??
Old Oct 18, 2011 | 01:34 AM
rm1sner's Avatar
I was driving down the highway and my firebird just died and wouldn't start. I got it home and found out that it wasnt firing. I replaced the coil, pick-up coil, and module, as well as the cap and rotor. Any suggestions on what I should try next?
Old Oct 18, 2011 | 02:17 AM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: 88 Firebird Formula 350 won't fire??
The engine turns over but won't fire?
What is the fuel pressure?
Do you have spark?
Do you have VATS? If so, is the "security" light illuminated on the dash? It should be near the "brake" light, etc...
Hope this helps.
Old Oct 18, 2011 | 03:10 AM
rm1sner's Avatar
It turns over but won't fire.
Pressure is good, no spark and no security light.
Old Oct 18, 2011 | 01:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Check fuses and fusible links by the battery and down by the starter.
Make sure your getting 12volts every place it needs to b.
Old Oct 18, 2011 | 01:30 PM
skibum2100's Avatar
Car: 1988 GTA
The only thing you haven't replaced yet are the wires and plugs.
Are you sure the injectors are firing? Maybe the injector fuse blew.
You could try to start the car using the ICM instead of the ECM (ignition system wise), by disconnecting the brown wire, 1-wire connector, located above the heater box on the pass side. It is the same connector that must be disconnected to set the timing. If the car has spark with the 1-wire connector disconnected there may be a problem with the ECM.
note: CODE 42 will be set if you run the car off the ICM instead of the ECM
Does the engine sound the same now as it did before, when you are trying to start it?
Good luck.
xkingcodex
Feb 12, 2020 07:43 PM
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
