Stalls when it's in gear
Old Oct 19, 2011 | 03:33 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I'm having a problem with my car, where it will stall if it's in gear and it is standing still (like sitting at a stop light). The motor will idle at about 600rpms when I put it in drive or reverse, and will start to stutter and stall if I don't tap the gas. It's fine while driving. These problems only occur when the car is cold.
I don't drive it all that much and it sits outside, if that could be causing it.
Any help is much appreciated.
Old Oct 21, 2011 | 08:44 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Re: Stalls when it's in gear
Same here. Mine runs like it has a huge cam unless I let it run for 5 minutes in the morning before I get in it. I think it's just the fact that the over the years clearances have become greater and the heat helps close it up.
GTAman
Jul 3, 2024 07:29 PM
IROCtometal
Sep 9, 2015 10:01 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
