88 Firebird Formula 350 won't fire??
Old Dec 6, 2011 | 02:51 PM
rm1sner's Avatar
My 88 firebird quit running a while back and I've yet to figure out what is wrong. It will turn over but won't start. I replaced the cap, rotor, pick up coil, and module all at the same time, it started for about 5 mins and died, now it won't start again. When it was started, I noticed it wasn't responsive when I hit the throttle. Any help would be great!!
Old Dec 6, 2011 | 03:02 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 88 Firebird Formula 350 won't fire??
Did you get the timming set properly??
Theres a few things it could be. We need more info..
Old Dec 6, 2011 | 03:28 PM
rm1sner's Avatar
Yes, timing was set. I had the module and coil tested just in case one was bad but it all tested good.
Old Dec 8, 2011 | 11:09 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
What is the fuel pressure at the fuel rail? If its low, change the fuel filter and hope.
Get an digital voltmeter and ohm check the injectors, they should all be 16+1 ohm.
Does it have VATS? Look for the security light to stay on when trying to start it, this would indicate a problem.
Hope this helps.
Old Dec 15, 2011 | 01:04 AM
rm1sner's Avatar
Fuel is good, there is not fire through the plug wires. I've replaced everything in the distributor and even retested the module like ten times.
No VATS either.
xkingcodex
Feb 12, 2020 07:43 PM
okfoz
Mar 9, 2017 02:35 PM
theshackle
Mar 5, 2017 06:37 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
