Building a TPI fuel system
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Building a TPI fuel system
you might want to rethink this, I have used Competition Engineering C4040 Gas Tank Sump on the bottom of a stock 67 camaro tank and a external acdelco ep185 pump and used the stock tank supply as a return and had no starvation issues. if your needing a afpr to compensate for engine modifications you can just upgrade your stock tpi regulator. Or you can do it like this....
http://www.popularhotrodding.com/tec...ank/index.html
Car: 1984 Trans Am
Axle/Gears: Stock
The AFPR (Adjustable Fuel Pressure Regulator) IIRC is built on the TPI fuel rails themselves. Its placement should be the esiest part of the swap.
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Hey man, if you are doing a custom set up , just use the rails. I threaded two fittings to the rear of each rail and then use the rails that T-back into one line that goes to the FPR
Here are a couple pictures
The line that splits into two is the feed and the single coming out is the return that goes to the regulator......
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I recently saw these fuel pickups, and thought they might be a good alternative to baffling. Looks like they can even be installed in series in the tank.
http://apeusa.com/html/pickups.html
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
