maf shock?
Old Dec 29, 2011 | 05:49 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
maf shock?
I was datalogging my friends formula tpi (32B) and was following the gm/sec. At idle(.65v), it was reading 12-15, light throttle(.88) it went up to 35- held for 5 seconds, dropped to 20, popped back up to 35, then fell back down to 20. It has been quite random, most noticeable on light take-offs.
Old Dec 30, 2011 | 12:52 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: maf shock?
Light throttle is when the EGR is trying to work, that is if the car still has a working EGR. The EGR feeds the engine unmetered air at intervals during light throttle.
Old Dec 30, 2011 | 06:33 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Re: maf shock?
Ok, but why would I get a reading on the maf? Essentially the maf is reading more air and leans out. It drops in the reading, car runs fine. I'll post a screen shot tomorrow.
Old Jan 1, 2012 | 01:34 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: maf shock?
What makes you say it leans out? The MAF output determines how the ECM calculates injector pulse-width. A higher MAF output would result in more fuel delivered.
Old Jan 4, 2012 | 02:55 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Re: maf shock?
That would make sense, so wouldn't the mv go up? take a gander at the pic attached. I was holding the throttle steady in park, light throttle.
File Type: pdf
Old Jan 4, 2012 | 04:00 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: maf shock?
So with a steady throttle your engine RPM is jumping up about 400 RPM intermittently?
I would try disabling (blocking) the CCP, EGR, and AIR functions and do the test again, - at least for a first try at troubleshooting.
Old Jan 4, 2012 | 04:27 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Re: maf shock?
tried another maf and running better, slightly rich
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
