305 TPI-Aftermarket Runers / Base ?
Old Jan 7, 2012 | 07:00 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I have a 91 305 TPI, it came with the dual cats, now has the Hooker 2055's and 3" exhaust...
I need to replace the fuel injectors... I got a ported plenum (which I will use), and I am purchasing AS&M runners & Edelbrock Base (which I want for a future 383)...
While I'm getting into replacing the injectors, should I replace the base and runners or would the 305 suffer?
It does have the same cam the 350's had in 91 and 92, and I can tune the car, EBL P4... Stock heads...
Just wondering... If not, I'll just use the ported plenum and save the runners / base for the 383...
Thanks,
Rafael
Old Jan 7, 2012 | 07:23 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: 305 TPI-Aftermarket Runers / Base ?
With a mostly stock 305 and putting on the high-flow base and long-tube runners, I have personally seen either zero gain, or approximately 10 HP gain depending on specifics of the install and the particular tune.
I have yet to see a power loss from adding these parts, but I'm sure some people out there have managed it.
It may turn out the you notice more gain or loss from your injector install than with adding the high-flow intake parts.
If you port match everything and block off the exhaust (EGR ports) from the heads to the intake, then you are sure to get a small but noticeable gain.
I wouldn't expect anything big though. If your heads are stock/untouched, then that's where most of your restriction is right now, specifically in the bowl areas around the valve-seats.
Once the heads can flow more, then the high-flow base & runners will earn their keep, even on a 305.
Old Jan 7, 2012 | 07:57 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I wouldn't wast your time swapping it out on a 305.
Jake_92RS
Jan 28, 2020 10:37 PM
tom1985
Apr 19, 2016 07:55 AM
FireDemonSiC
Sep 3, 2015 12:31 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Keith5
Aug 27, 2015 04:37 PM
