TPI to carb swap
Old Jan 9, 2012 | 02:16 PM
dmtulsa's Avatar
TPI to carb swap
I'm switching from a TPI setup to a carb. I have installed a 5-7lbs fuel pump but it only has an inlet and outlet. Do I have to have the recirculating line connected, if so how? I know on the older mechanical fuel pumps there was no recirc. I just don't know about the electric ones. the pump is a summit SUM-G3136-1
Thank you
Old Jan 12, 2012 | 10:23 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: TPI to carb swap
I ran a similar pump years ago on a carb'd application, and I did not use a return line. You should be fine, as long as the pump pressure is not too great for your carb.
Old Jan 13, 2012 | 10:57 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
