OK LADIES AND GENTS - Difficulty amd Cost - WORTH IT??
Old Jan 13, 2012 | 07:58 AM
GOTMYZ's Avatar
Car: 1986 Z28
Engine: 305ci
I am still hunting for the right replacement! I think I found one, but have some questions...
I came across a Yellow 1989 IROC-Z. It has a Turbo 350 Tranny and a 600 CFM Carb. YEP - Somebody swapped out the TPI and the 700R4!!!
Wiring harness is gone and the computer is most likely gone.
What kind of cost is involved in switching this back to TPI? Would the CARB and Intake have any resale value?
How difficult is this process?
The car has a few other issues, but they do not bother me. Cluster is not working and starter is shot.
Old Jan 13, 2012 | 09:07 AM
projectredsled's Avatar
Re: OK LADIES AND GENTS - Difficulty amd Cost - WORTH IT??
is it worth it? depends on your budget and your taste. I purchased my car with the intentions of converting it back to TPI like my previous third gen but after getting the carb tuned correctly I QUICKLY changed my mind and kept the carb.
As far as resale for the carb and intake. You could sell them at a local swap meet pretty easy and might have luck with craigslist but swap meet is your best bet. Around my area it is hard to sell a used carb for anything more than $40 or $50 because they are all over craigslist but I took 2 of them to a swap meet and sold both for $100 each easy. The intake should also be an easy sale as long as it is a decent intake.
The hardest part of going back to TPI is finding a decent wiring harness (or go aftermarket but it is costly) and you would also have to work out something for te fuel pump and lines (most of the time when someone converts from TPI to carb the usually hack the back of the car up really bad to get to the pump from up top and then cut the fuel lines, pull out the EFI pump, stuff the pump back in (most of the time without putting the o-ring back on) and then use hose clamps to "repair" the fuel lines. Have only seen 1 person do it the right way and drop the tank but have seen dozens done the wrong way.
Old Jan 13, 2012 | 09:40 AM
GOTMYZ's Avatar
Car: 1986 Z28
Engine: 305ci
Budget is not even in question at this time. This is a long term rebuild.
My last Camaro was a 92 RS with TBI. I liked it but had crap power. I like TPI but I have nothing against CARBs. I started to pric out the wiring harness and it looks like $500 for that and then I need intakes and runners and injectors. That jumps another $500 or so.
Sounds like the CARB made you smile!!??
Old Jan 13, 2012 | 10:03 AM
Yeah the day I picked it up and drove it home I was very disappointed in the power and when i got home I took the carb off and noticed that the fuel that cam out of it was dark brown. I figured I might as well rebuild it so I could sell it as a fresh carb and once I got it apart it looked like crap inside. After the rebuild I figured I would bolt it back on just to see the difference and make sure it all functioned. Needless to say the carb is still on there and I smile everytime I take it for a drive. It also meant that all the money I had put aside for the TPI swap can now be used on other things to make it faster.
Old Jan 13, 2012 | 10:32 AM
GOTMYZ's Avatar
Car: 1986 Z28
Engine: 305ci
It has a carborated 350 smallblock, and a 350 turbo tranny.
The engine does have some performance parts like headers, a holley intake manifold and carb. It also has a nice accel distibutor, high flow cat, flowmaster exhaust, and aftermarket gauges mounted inside.
Old Jan 13, 2012 | 10:45 AM
very nice! post up some pics so we can see it. I dont personally like the TH350, it is a good trans for the track but I prefer a 700R4 trans or manual so that I can have the overdrive on the highway. I have a 5 speed in mine right now but have plans to go with a 6 speed in the near future. What size Holley does it have? Mine came with a 600 cfm and I bolted a 750 on it to see how much of a difference it was. It had a little more pull on the top end but the low end felt really soggy so i put the 600 back on and not it has a nice crisp throttle response
Old Jan 13, 2012 | 11:03 AM
GOTMYZ's Avatar
Car: 1986 Z28
Engine: 305ci
The owner claims 600cfm
Attached Thumbnails OK LADIES AND GENTS - Difficulty amd Cost - WORTH IT??-5u45p35s33n83k43p0bcdab0cd12fed3d178c.jpg   OK LADIES AND GENTS - Difficulty amd Cost - WORTH IT??-5q55t45x63m93o83l2bcd77d5b6a2dedc1ac6.jpg   OK LADIES AND GENTS - Difficulty amd Cost - WORTH IT??-5v55w05u53m03od3l5bcd331992dd220b1a2b.jpg
Old Jan 13, 2012 | 11:05 AM
GOTMYZ's Avatar
Car: 1986 Z28
Engine: 305ci
I am not a fan of this transmission. It would become a 700R4 or a 6 spd manual. I loved my 700R4!
Old Jan 13, 2012 | 12:41 PM
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
There's a guy in this thread that is going from TPI to carb, perhaps you two should talk! https://www.thirdgen.org/forums/tpi/...carb-swap.html
Old Jan 14, 2012 | 07:38 AM
Davejs's Avatar
What he said or find one to part out that has a complete drivetrain and crap body.
Old Jan 14, 2012 | 09:56 AM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
get a wire harness from pocket on the board 175 bucks is not bad and its labled cant go wrong im doing this swap right now (with heads and cam swap) not that bad it just takes alot of time the crappys part is the fuel tank and droopping it for a fuel pump inside the tank.
You will love the look and cant tell you about the power cuz im still rebuilding mine
check out my thread some time man
and you can find tpi units on the thread all day and i think hawksthirdgen sells the setup for 600 bucks or so for the whole seteup
Old Jan 14, 2012 | 10:14 AM
Davejs's Avatar
Depending on your budget you could drop on Vortec heads and SDPC manifold with better runners. Even with a mild cam that thing will have the power and Tq to make things happen.
Old Jan 14, 2012 | 10:25 AM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
are you sure that's an 89? I didn't think made yellow ones after 87. Anyway, if you decide to do the tpi swap,the throttle cables are different from carb and tpi.
When buying a fuel pump I recommend an AC Delco unit. I tried using an A-ZONE pump once and it was crap out of the box TWICE!!
Old Jan 14, 2012 | 11:35 AM
Davejs's Avatar
Option B is go aftermarket injection with more power right off that bat and more easy to upgrade.
Old Jan 14, 2012 | 05:33 PM
BuzzLOL's Avatar
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
.. If budget isn't a problem, as you say, then I'd look for a car (in nationwide listings) somebody hasn't butchered up already!!
.. Or, if sticking with this one, go Holley Stealth Ram rather than begin the process/battle of trying to find great power from the restrictive stock TPI setup which quits making power at a lowly 4500 RPMs on a 350"......
Old Jan 14, 2012 | 09:58 PM
irocarter's Avatar
Car: 89 iroc
Transmission: wct5
right on BUZZ
OR short shift with that tpi!
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
