TPI to 96 Camaro Fuel Injection
Ok I have a 1991 Camaro z28 with a stock 305 TPI. It's a 5 speed car. I have a 96 Camaro fuel injection laying around and I was wondering if it was possible to put it on my motor? Will there be conversion issues? Also, what are the stock fuel injector specs on the 96 camaro fuel injection?
Thanks for the help!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI to 96 Camaro Fuel Injection
here is no way to run the optispark of a lt1 on a gen 2 sbc . you can run the 411 ecm but seems to expensive. The lt1 injectors are 24#hr your lb9 are 19#hr stock.
http://forums.corvetteforum.com/c4-t...e-for-l98.html
http://www.eficonnection.com
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Plenty of guys had success with converted LT1 intakes on a TPI engines
( using TPI computer and wiring ) before TPI replacement intakes became affordable
http://www.popularhotrodding.com/tec...ls1/index.html
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
