Timing Question
Old Mar 20, 2012 | 10:44 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Timing Question
The spec on my 91 L98 is 6 BTDC at 400 RPM, now because of the cam the car wont idle at 400, i need to raise the idle to about 800 but where do i set timing at 800 to?
Old Mar 20, 2012 | 09:01 PM
utilityguy2's Avatar
Re: Timing Question
400 is not correct. should be 6 degrees btdc with the timing wire disconnected at whatever idle is set to, usually around 750 rpm.
See link here: https://www.thirdgen.org/settingtiming
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
