Accel injectors
Old Mar 27, 2012 | 01:22 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Accel injectors
Anyone have an issue installing these injectors?
I feel they dont sit in the rails properly.
Anyone install these without the clips to the rails?
Old Mar 27, 2012 | 01:47 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Accel injectors
Ive used them B4, no problems. Did u use a lube on the O rings? That helps them fit better.
Old Mar 27, 2012 | 03:04 PM
transamice's Avatar
Car: 87 GTA t-top
Re: Accel injectors
They fit on fine , and used a dab of oil on the o-rings to push them in but I felt they sit out further than the stock style injectors.
Just concerned about that, even though it has that little slip with the injectors that mentions most GM vehicles need to clip the top tab.
Im just trying to figure out why my fuel pressure isnt stable, eliminate all possibilities.
Old Mar 28, 2012 | 02:45 PM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
Re: Accel injectors
I put them in a couple years ago. No clips on mine. I just couldn't get them on right. But a couple years and no problems. As long as the orings pop in u should be fine.
92-Formula
Dec 12, 2015 10:34 PM
85 Jimmy
Sep 30, 2015 07:56 AM
webeeZ28
Sep 14, 2015 12:00 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
