No Spark
Old Mar 27, 2012 | 06:17 PM
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
No Spark
Did a tuneup on my 89 since it had a hard start condition and now it has no spark. I checked from the coil and has no spark either. It will show a slight flicker right before I stop cranking, but not enough to start it. Battery has 12.2 volts. I need help... this car is pissing me off and I don't have an Extra LS1 to swap it, nor do I have the time.
Old Apr 4, 2012 | 01:29 PM
92RSTPI's Avatar
Car: 1992 RS Heritage
Transmission: WC T5
Axle/Gears: 10 bolt, 3.73
Re: No Spark
Check the ignition module. Replacement cost ~$20, and they go bad frequently. It is under the dist cap. One of the harnesses plugs into it
Old Apr 5, 2012 | 11:04 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: No Spark
I guest module also but it will be more that $20,and make sure you put the grease under the module before you install it.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
