Lost Vacuum hose
Old Mar 30, 2012 | 10:00 PM
ruiterman's Avatar
Car: 91 Z28, 89 Formula, 85 IROC Z28
Engine: 305 TPI, 305 TBI, 305 TPI
Transmission: 5 Speed, 5 Speed, 700R4
Lost Vacuum hose
I can't believe this. I am re-installing the intake on my '85 IROC Z28. I took pics as I took it apart, but I didn't turn out to have a good pic of the vacuum lines on the passenger side of the dizzy. I for some reason, the vacuum line that connects to this vacuum switch in the attached pic, I can't find. I know there was something connected, but I can't find it. The plastic lines on the right of this vacuum switch module go to the EGR valve, and to the front bottom of the throttle plates.
I think the rear vacuum line I'm missing may go through the firewall to the heater controls, but 1, I'm not sure, and 2, I can't find the line. Can someone help me confirm what vacuum line this is supposed to be, and help me with where it is supposed to come from.
Thanks so much.
Ed
Old Mar 30, 2012 | 10:54 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Lost Vacuum hose
Any help here?
http://chevythunder.com/fuel%20injec...cuum%lineshtml
Old Mar 30, 2012 | 11:11 PM
Car: '87 Camaro
I can't verify the link, I can't get it to work! BOOO!!!
http://
www.
chevythunder.com/
fuel/%20injection%vacuum%lines
html
I searched
1985, IROC, Z28, vacuum, lines, diagram
chevythunder had a decent diagram
Sorry my computer skill is less than " Dummy "
Old Mar 31, 2012 | 12:17 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Nothing connects back there.
https://www.thirdgen.org/forums/post...12-post33.html
Old Mar 31, 2012 | 05:36 PM
ruiterman's Avatar
Thanks guys. I that helps a bunch. I really appreciate the quick response too.
Old Apr 1, 2012 | 01:12 AM
Old Apr 5, 2012 | 01:14 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
As Chevy86 says, no line attaches there. That is a vent to relieve vacuum from the EGR solenoid. It had a little foam filter on it originally but the foam tends to rot and fall apart over time.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
3.8TransAM
Sep 27, 2015 08:37 PM
