Injector choices help please
Old Apr 3, 2012 | 07:13 PM
Blitzkrieg91's Avatar
Car: 89 Iroc
Trying to replace my injectors in my 86 305tpi. Quick question advanced auto parts said bosch part # 0280150238 but found some on ebay with # 0280150222 and was wondering if they would work?
Old Apr 3, 2012 | 09:13 PM
Car: 89 Iroc
Re: Injector choices help please
http://item.mobileweb.ebay.com/viewi...id=86166903342
Link of one i found on ebay. Idk the kind in the car now the only writing i can see without taking apart is H-30
Old Apr 3, 2012 | 09:35 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I would just upgrade to the bosch 3 from southbay fuel injectors, make sure you tell them your a tgo member for a 10% discount.
http://www.southbayfuelinjectors.com...o_305_TPi.html
Old Apr 3, 2012 | 09:52 PM
bronc3buster84's Avatar
Car: 2001 GMC Jimmy
Transmission: Nv3500 5 speed
Axle/Gears: Dana 44's f&r, 4.30 gears
I have a set of the Bosch 3 19's forsale if your interested.
Old Apr 4, 2012 | 08:52 PM
erik69&85's Avatar
can't go wrong with 19lb Bosch 3 injectors from South Bay. Made a huge difference in my car (92 TPI). Idles better and mileage got a lot better.
Just saying....don't fool around with the injectors can make such a difference.
Old Apr 4, 2012 | 09:22 PM
Car: 89 Iroc
Are they a direct fit i read something about slightly smaller?
Edit: stupid me didnt read and answered question
Old Apr 5, 2012 | 07:14 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Another vote for Southbay... got my 19lbs Bosch III's...
They add an adapter to them to make them stock height, so if you have an aftermarket tpi base, tell them, you won't need the adapters they put on... they have a 3 year warranty, and give a discount! Car is running and idling better for me too... 91 TPI 5 speed...
Rafael
Old Apr 12, 2012 | 11:55 AM
Nelz's Avatar
I got 36lb. Bosch iii's from InjectorsPlus with a lifetime warranty for $240 roughly and am now asking about the fitment issue. They are slightly shorter than the stock Multec injector and do not use a retaining clip to keep the injector in the rail. South bay used to use an additional o-ring to solve the height issue before installing an adapter and I am now looking into that. John at InjectorsPlus has been a great technical resource and I'm just waiting for his reply. My injectors are going into a SDPC vortec base with the Superram. I don't know why you would limit yourself to 19lb injectors if you're going to mod your car for more power later. You're going to need to tune the car and your motor is going to need more fuel anyway later.
Old Apr 12, 2012 | 12:12 PM
Engine: Lb9
Transmission: M20
You shouldn't recommend larger injectors on a stock-ish Lb9, he would have a difficult time tuning for that. It's not like you can run even a #22 and get the pressure down low enough to flow the engine's needs it will still be running too rich. wow 36#hr are you running a 383 with boost
Old Apr 12, 2012 | 12:35 PM
Nelz's Avatar
Yea, I'm running a 383.
http://www.youtube.com/watch?v=Emnax...feature=relmfu
Old Apr 12, 2012 | 12:47 PM
Engine: Lb9
Transmission: M20
Yea, I'm running a 383. The difference between the stock LB9 19 lb injector and L98 injector is the fuel pressure.
No that is incorrect 19#hr and 22#hr run at the same fuel pressure you are comparing orifice size.
Old Apr 12, 2012 | 12:53 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
I've been looking at South bay, too. But I don't know what size to get. Going to be a vortec headed 350 tpi with lt4 hot cam.
Old Apr 12, 2012 | 01:07 PM
Nelz's Avatar
Use a fuel injector calculator:
http://www.witchhunter.com/injectorcalc1.php4
Or this calculator (this takes into account fuel injector rail pressure)
http://injectorsplus.com/calculation-tools.asp
Old Apr 12, 2012 | 01:08 PM
Nelz's Avatar
Tuned performance, you are correct, I realized my error and edited my reply. The video he was talking about the Ford Injector
Old Apr 12, 2012 | 01:37 PM
Nelz's Avatar
Notice how on the fuel injector calculator, 19lb injectors at an 80% duty cycle and rail pressure of max out at 242 HP. If you have an adjustable fuel pressure regulator (and want to spend the money for it!) then you could get 262 HP out of 19lb. injectors. So think hard about what mods and power level you can get out of your combo because buying injectors twice is a waste of money. Instead of having $200-300 for headers, cat back, tuning or whatever, you're going to have to spend it on another set of injectors because you decided to switch/port your heads and change cam and now you're running lean and close to burning a hole in the piston of the motor.
Keep in mind that switching injectors requires recalibration of your prom if you go up in injector size. So you need to budget for that too.
Old Apr 12, 2012 | 05:06 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
another vote for southbay. 10% discount for us tgo members
Old Apr 12, 2012 | 06:03 PM
Engine: Lb9
Transmission: M20
flow rate =(HP x BSFC) / (#Injectors X Maxcycle) your correct it's not wise to run over 80% Duty cycle if you want the injectors to live for very long.
Support Southbay They Support TGO !!
Old Apr 30, 2012 | 04:42 PM
ScreaminChicken's Avatar
Just got a set of Bosch IIIs from Southbay, but they are gray instead of yellow, with part #XS4U-AA 0-280-155-887. Can anyone tell me the correct color/part # from their Bosch IIIs?
Thanks!
Old Apr 30, 2012 | 04:55 PM
Engine: Lb9
Transmission: M20
Thanks!
Those are the 17#hr for a GM 3.1L
16.75 at 43.5 psi
you need there 19#hr for a tpi 305
Old Apr 30, 2012 | 07:08 PM
16.75 at 43.5 psi
That's what I thought. I'll call him tomorrow & try to straighten it out.
Were everyone else's yellow, gray or white? What is the part number on the real 19#/hr Bosch IIIs?
Thanks again.
Old Apr 30, 2012 | 10:28 PM
southbay08's Avatar
By all means give us a call if you still have any questions.
Old Apr 30, 2012 | 10:49 PM
Engine: Lb9
Transmission: M20
all the pretty colors confused me.
Old May 2, 2012 | 02:53 PM
It seems the Bosch IIIs came in both whitish-yellow and gray colors. (The dark yellow ones are 22lb/hr, whereas the whitish-yellow and gray ones are 19lb/hr.) The gray color is what is mainly available now. Not sure why all the companies use the pictures of the whitish-yellow one when they send out gray ones?
Southbay said they'll update their site with pics/info about the gray ones soon
Old May 2, 2012 | 03:28 PM
southbay08's Avatar
Hi Guys,
sorry for the delay, will have the pics posted by tomorrow.
Old May 3, 2012 | 03:01 PM
southbay08's Avatar
Ok, so here is a pic of the 19lb bosch lll injectors....the white and the gray color that was in question. Both injectors flow 103cc static for 30 sec.
That is equivalent to 19.6 lb @ 43.5psi. We need to get a pic of the gray ones on our website so there will not be so much confusion.
If anyone has any questions please contact us
516-442-4707
516-492-6504
Attached Thumbnails Injector choices help please-tgopic2.jpg   Injector choices help please-tgopic3.jpg
Old May 3, 2012 | 03:21 PM
Looks great, thanks!
Old May 3, 2012 | 03:47 PM
Engine: Lb9
Transmission: M20
yeh south bay !!
Old May 3, 2012 | 05:29 PM
southbay08's Avatar
LOL....hope it helps
Old May 3, 2012 | 05:59 PM
ss6911's Avatar
Car: 92 Camaro Z28 convertible
i was just at south bay wed they are nice people and very helpful i got the bosch 3 19pounds injectors nice clean shop recommend south bay would not use any one else roger
Fronzizzle
Feb 9, 2017 09:31 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
ericjon262
Sep 11, 2015 06:07 PM
