tpi help
tpi help
i am building a 32 coupe with a tpi motor. its a 88 motor and i was seting it up with the 88 harness and air flow sensor. well it looked funny with the open hood but these little punks broke into my garage and stole all my copper wiring and cut the harness outta my car. i caught them week later but copper was gone. i am starting from scratch. i am buying a new speed density harness this time and computer. advanced has a new computer for $80 but there are 4 different part numbers. can u guys steer me in right direction please. what else will i need other than the harness and computer? i know a map sensor is used with this set up. what relays other than fuel?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tpi help
01227730, 1227730,16196344, or 16198262 all the same ecm just superseded numbers. The only relay you need for sd is fp unless you are using the ecm to control the coolant fans. I have a few of these ecm's pm me if you are interested.
Sanjay
Aug 12, 2015 03:41 PM
