87 carb to 87 tpi.......
Old Apr 26, 2012 | 04:21 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Hey all,
Simple questions for ya real quick
A. Is interior wiring same as a tpi car as carb?
I have a 87 iroc with blown lb9 and rotted out, and am looking at a 87 z28 that's lg4.
Is the drivers side (c100) iirc connector the same? And as for the passenger side?
Id rob the iroc for fuel lines and all the other efi goodies, I think it would be worth it to swap in a tpi setup and a fresh 350
Old Apr 26, 2012 | 07:57 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: 87 carb to 87 tpi.......
no the wiring is not the same on the passenger interior.
Old Apr 26, 2012 | 11:55 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Well dang, so the dash harness is different? Ok thanks
I know the 87 carb cars have a fuel pump in tank so it has wiring to tank. Biggest thing is changing the fuel lines and pump. I've got a walbro 255lph ready to go in from my old trans am.
Idk seems like a lotta work lol
Old Apr 26, 2012 | 12:01 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yeah they have a wire by the pump, i put an intank pump, you need to change the sending unit to mount the electric pump, then the dash harness is different, replace or pin it out..
Old Apr 27, 2012 | 02:30 AM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
ok sounds like best just to stay carb for now and strip the iroc and wait til winter and do the whole swap
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
