PLEASE DELETE!!
Old Apr 30, 2012 | 06:13 PM
84'B.A.T.A.'s Avatar
Car: 88 Iroc-Z
Engine: 388 HSR
Axle/Gears: 9 Bolt 3.70
PLEASE DELETE!!
Hi everyone, a few months back I bought an 88 iroc 350 tpi. I drove it home pulled the motor and trans out. Built a 388 stroker with 4L80E behind it. I cant get this thing to have any fuel pressure!!! I didnt think that I would have to have any sensors installed to test fire the system. It cranks over fine, has spark, ZERO fuel pressure.
I replaced the fuel pump relay... no change. Found blown main fuse near battery replaced... no change. started slowly installing sensors... no change...
What NEEDS to be hooked up/checked in order to get the fuel pump to prime. I drove this car to my house the fuel pump was just fine. I dont ever remember it priming when I first got the camaro either. HEEEELLLP! Please this is my first efi build, am very familiar with carbs, distributors and chevy motors. Thanks in advance!!
Old Apr 30, 2012 | 07:02 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: Need HELP cant get 388 HSR running!!
Look at your wiring harness by the heater box. There should be a single wire connector with nothing plugged into it. Apply 12v to this connector and the fuel pump should run. If it does, your problem is elsewhere. If it doesn't, you need a new pump.
Old Apr 30, 2012 | 09:13 PM
Car: 88 Iroc-Z
Engine: 388 HSR
GOT IT THANKS!!!! mods please delete!!
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
