5.0L TPI swap into my 5.0L TBI
Old May 9, 2012 | 07:39 AM
jloomis95's Avatar
Car: 1992 CAMARO RS 25TH ANNIVERSARY
Engine: 3.1 V6
Transmission: AUTOMAGIC
Axle/Gears: STOCK
I have a 1991 rs camaro. It has a 5.0L TBI engine in the car that needs to be rebuilt. I wanna swap it over to a TPI system cause I am pulling the engine as it is. If someone could enlighten me to what items i would need to swap to make this successful I would greatly appreciate it. THANKS 3RD GEN MEMBERS!
Old May 9, 2012 | 09:09 AM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
Re: 5.0L TPI swap into my 5.0L TBI
fuel pump, computer and chip, wiring harness or modify original if using sd,rubber fuel hoses going to intake, tpi intake system, and maybe the est
Old May 9, 2012 | 11:21 AM
jloomis95's Avatar
Engine: 3.1 V6
Axle/Gears: STOCK
Thanks for the Info. could you elaborate on the parts in the tpi intake setup. and what do you mean by "est". Thanks again for the speedy info!
Old May 9, 2012 | 01:23 PM
irocarter's Avatar
Car: 89 iroc
Transmission: wct5
everything from the tpi intake up (egr, fuel injecters, trottlebody,fuel rails, plenum, intake runners, thermostat housing, torx bolts, fuel pressure regulator).
est stands for electronic spark control. It's usually a black plastic flat box located on the driver's side of the firewall. it's got something like 5-7 wires coming out of it.
There are several other differences involded in the speed densidy (sd) and the mass air flow (maf) tpi systems. The conversion is not a simple task the first time around. Your best bet is to start reading the hundreds of old threads on this topic and everybody will tell you that it's easiest if you can get all of your parts from the same donar car. Also take note that there some differences in 305 and 350 tpi (computer chip and fuel injecters to name a couple). search search search then search some more and good luck.
Old May 9, 2012 | 02:05 PM
jloomis95's Avatar
Engine: 3.1 V6
Axle/Gears: STOCK
alright, thanks again for your time and of course all the info!
Old May 9, 2012 | 03:34 PM
algershick's Avatar
To add to what irocarter said, 305's and 350's use a different knock sensor.
Old May 10, 2012 | 07:09 AM
jloomis95's Avatar
Engine: 3.1 V6
Axle/Gears: STOCK
Thanks again for the help, but would someone be able to find me a link to a thread involving rewiring the wiring harness from TBI to a TPI system? and would I be able to use any TPI computer for a 305 with my retrofitted harness?
Old May 10, 2012 | 02:28 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
you will also need the tpi throttle cable and transmission kick down cable as the tbi ones are too short.
your best bet is to find a 1991 tpi donor car and strip anything you can use out of it
there is a sticky posted at the top of this forum regarding repinning the tbi harness
BRoss99
Aug 10, 2025 05:08 PM
92camaroJoe
Jul 29, 2023 07:57 PM
xkingcodex
Feb 12, 2020 07:43 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
