Mongrel engine, which fuel pump??
Old May 31, 2012 | 11:27 AM
plstu's Avatar
I bought a 1992 TPI Camaro that has the L98 engine stroked out to a 383. The difference is that it is all Vortec from the heads up with a BBK 58mm TB. The fuel pump has died and I am not sure which one to buy! Should I match the pump to the 1992 L98 engine or step up a year and go with the LT/LS pump? I think either pump will work but I am thinking the output pressure of the pump is higher on the LS/LT pump. I am running an adjustable fuel rail pressure regulator.
I am thinking the Granatelli GM722-2
or
Walbro GCA758-2
or
AC Delco EP241
From what I can tell, all pumps should fit my tank and sending unit but the Granatelli has the highest output pressure! What do you guys think?
Should I go about this differently and identify what the car is running for Injectors and match the pump to them? All I can see is that they are orange.
So, stick with the pumps listed for the 1992 (L98) or go with the pumps used on the newer LT/LS cars?????
THANKS in adavance!!
ADDED: Just identified my injectors and they seem quite small! AT 43.5 PSI the rated flow is only 210cc. I am thinking this engine must be pushing 400 HP+ at the crank and therefore I should be running around 360cc???? What do you guys think?
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
