Shaking at idle
Old Jun 3, 2012 | 05:26 PM
90_T/AGTA's Avatar
Car: '90 GTA
Shaking at idle
91 Z28 5.0 5speed
Recently had tune-up plugs,plug wires,distributor cap, rotor,new injectors,fuel pump,fuel filter.
when your at idle the car shakes when you shift to change gears it will back fire and shake in low rpms. all the plug wires are in correct order and the timming is also correct.I pulled the plugs cylinders 5,6,7,8 look to have oil on them. cylinder 8 look to have a flat black look,cylinder 5,6,7 had a bit of a gloss look to them.Is this valves? worn rings? the car is not burning any oil.
Old Jun 3, 2012 | 06:45 PM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
Re: Shaking at idle
Check you fuel pressure.
Old Jun 3, 2012 | 08:13 PM
90_T/AGTA's Avatar
Car: '90 GTA
Re: Shaking at idle
Checked fuel pressure
With key on
40 PSI, in about a minute in drops to 30psi
With the car running 35 psi with FPR vac line off 43 PSI
Possible fuel problem?
Old Jun 4, 2012 | 06:38 AM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
Re: Shaking at idle
A leaky diaphragm would make the gauge needle wiggling or would not keep the pressure at all.
Just to make sure, you put same size injectors? Do you have any check engine code?
Old Jun 4, 2012 | 07:46 AM
90_T/AGTA's Avatar
Car: '90 GTA
Re: Shaking at idle
Injectors are 19lb and no check engine light.
Old Jun 4, 2012 | 06:59 PM
90_T/AGTA's Avatar
Car: '90 GTA
Re: Shaking at idle
Bump
The car smooths out past 2k rpm any thing under that and it is shaking.
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
88rscamar0
Sep 23, 2015 09:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Amillionoh7
Sep 5, 2015 11:44 PM
