need help 89 iroc
Old Jun 12, 2012 | 12:46 PM
lt1zr28's Avatar
need help 89 iroc
On TPI I have a wire with the end broken off it is about 2 foot long and black in color.It starts as a green wire about 3 in. with a black connector then the black wire.It is in the main harness at the back of the motor on driver side.Have attached a pic.Any help would be greatly appreciated.Thanks
in advance.
Old Jun 14, 2012 | 12:51 PM
lt1zr28's Avatar
Re: need help 89 iroc
Doesn't anyone have this wire?Because i know i'm not the only one with a TPI motor.
Old Jun 16, 2012 | 12:00 PM
PDX88IROC's Avatar
Car: 1988 IROC
Engine: 5.0 TPI
Transmission: 5 spd T5
Axle/Gears: G80,G92,3.45
It looks to me like the one that goes over to the temperature sensor that is up on the manifold under the intake plenum. It is the one that goes to the computer, not the temperature gauge, that one is between spark plugs 1 & 3.
Old Jun 16, 2012 | 12:35 PM
PDX88IROC's Avatar
Car: 1988 IROC
Engine: 5.0 TPI
Correction...I think it is the EGR Temp Sensor wire.
https://www.thirdgen.org/forums/engi...connector.html
See the connector goes from dk green to black.
Old Jun 16, 2012 | 08:57 PM
lt1zr28's Avatar
That is it.I figured it out last night. I appreciate your reply. No one else seemed to know or didn't want to help. Thanks again.
Old Jun 16, 2012 | 11:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Might have got a better response if your heading said " unidentified wire"
and you posted in the electronics section where wiring experts hang out ?
Old Jun 17, 2012 | 01:33 PM
lt1zr28's Avatar
I posted here because i have a TPI motor and figured anyone with a pre 90 tpi could take a look at theirs.As others would not have this wire.As for my heading that was so every one would know what i was dealing with.I usally check New Post when ever i'm on here thaught others might to.
Really no bigdeal.
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
mustangman65_79
Aug 23, 2015 02:00 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
