89 TPI Fuel Pump Flow Rate?
Old Jun 26, 2012 | 03:47 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Only got 25 lb pressure at the rail. FSM says to check for obstructions, then replace the filter, then replace the fuel pump.
I want to test for obstructions by opening the fuel line before the rail and giving 12v to the pump and seeing it deliver something like at least a pint in 15 sec or something like that. I can't remember where I saw the flow rate, here or in the FSM.
Searched here but can't find an answer. Anyone know? Thx!
Old Jun 26, 2012 | 04:09 PM
TallTim's Avatar
Re: 89 TPI Fuel Pump Flow Rate?
Found it in FSM section 6C-5. 1/2 pint or more in 15 sec.
Old Jun 26, 2012 | 05:02 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Should be 42# at the rail and 15-18 gal. per hour.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
